20 Most Recent Sharp AR-M355N Copier Questions & Answers
2answers
Call for service. Code: L4-02
You need to make sure the machine is in Copy Mode then hit Pound, Star, C, Star enter 14, then touch start execute on the screen the machine will reboot and the code should go away. If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston. Skelton Business Equipment Houston Copiers http://www.youtube.com/equipmybiz
3/18/2019 5:33:23 PM • Sharp AR-M355N... • Answered on Mar 18, 2019
I'm trying to use my
Hi, When scanning to e-mail you would need to enter the details of a smtp server e.g. Gmail, as well as your DNS settings into the photocopier via the web browser. To access the browser, enter the I.P. address of the copier into the web address & this will give you the front page of the copier. To access the network settings you'll need the user name : admin & the password Sharp. Depending on the firmware version the machine must have SSL installed, if it hasn't then unfortunately you will not be able to scan to e-mail. The alternative is to scan to SMB (folder), again this is set up via the web browser. Hope this helps. Dave.
10/18/2017 9:23:13 PM • Sharp AR-M355N... • Answered on Oct 18, 2017
2answers
I Cannot Receive a Fax - the pages are blank
A second line isn't needed, this wouldn't cause blank pages to be printed. This could cause fax's not to be received if the line is in use. There could be 2 causes of blank fax's. Either the obvious which is the person sending the fax is faxing the document the wrong way up. Or the fax board on your copier has a malfunction. Because of the copier's age, this seems likely, although i hope not. hope this helps.
7/1/2016 12:15:06 AM • Sharp AR-M355N... • Answered on Jul 01, 2016
How do I set up an address to the frequently used addresses tabs on sharp ar m355n?
on the web page(accessed by typing the machines' IP address into a web browser) click destination, the username is admin, and the password is Sharp then put a check next to the person's name, and click edit then check the "Frequently used" box on the page and click submit. Skelton Business Equipment Houston Copiers
8/6/2014 2:05:21 PM • Sharp AR-M355N... • Answered on Aug 06, 2014
0answers
Code F2-02
Have you tried the sim 25-1 to see what the toner value is? Sharp pretty much just says check the connectors and the toner sensor then replace the toner. If you are using refilled toners that could be the issue. These are the troubleshootings steps for F2-02 in SM. Techsupport Printer
3/6/2014 8:55:42 PM • Sharp AR-M355N... • Answered on Mar 06, 2014
0answers
Error code e7 02 mean
check wiring at the scanner
7/8/2013 5:08:22 AM • Sharp AR-M355N... • Answered on Jul 08, 2013
Sharp AR-M355N Copier Logo
81 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
cannot receive fax pages blank
  • Office Equipment & Supplies
