20 Most Recent
Sharp AR-156 Copier Questions & Answers
Error h3 ar 00
heater/fuser error, probably need to replace or rebuild, call a tech
Code CH s.v.p.
i really need a code to reset AR-sharp 5320E which display developer light with toner light together at the same time
Sharp AR-156, with code H-4
H4: Heat roller abnormally low
temperature.
cause:-
Thermistor failure
Heater lamp failure
MCU PWB failure
Thermostat failure
Power supply failure
Execute Simulation 14 to reset
AR 150 Has H4 code
Hello sir; You need to reset your copier, procedure as follow;
Press "clear" "exposure" "clear" "exposure" then enter 14 press print.
How do I change the developer on a Sharp AR-156?
The developer sits in a small, black casing that houses the toner bottle. When you pull out the toner, look for a small, blue or green screw that holds the developer box in.
Once you pull the developer out, you'll notice three screws on the outer casing (two on top as you look down on the unit, plus one looking down into the opening where the toner bottle sits). Removed these screws and set them aside. You should now be able to pull the cover off the unit and expose the developer assembly.
Dump out the old toner in a plastic bag. Be careful, as it can spill out quite easily and it's a pain to clean up out of carpets. You'll want to invert the developer unit and use the plastic gear on the backside of the unit to spin the magnetic rod until all of the developer has been removed (be careful not to scratch the surface of this rod, as it's what holds the developer in place during copy processes).
Place the new developer into the open auger area of the unit. Put the cover back on and install the three screws you removed earlier. Place the developer assembly back into the body of the copier and screw the blue or green retaining screw back into place. Now you can re-install the toner bottle and start the copier back up.
Code F-2
Replace toner cartridge or maybe just the crum chip on the rear side
Sharp AR-156 will not copy
Usually that means the polygon motor isn't up to speed.
Try turning the copier off, wait 20 seconds, and turn the power back on.
Is there any other devices plugged into this electrical outlet?
E7
reset it first if you can all copier error code can be reset if the copier does not reset check the exposure lamp
