20 Most Recent
Sharp AL-1641CS Laser Digital Copier Questions & Answers
DARK SPOTS
Are the dark spots random and moves location with every copy or are they at exacly the same place on every copy? Random you will need to remove the drum/toner and use a blower to clean the inside of the machine,failing that replace the drum unit.If the spots don't move clean the top glass.Let me know
Sharp copier 1641cs
I am having a problem in copier sharp 1641CS, this E7 appears on the display, and with that the copier is dead ... What to do?
How do i clear error mx-26000x h5-01
Find out why it is jamming in the Fusing unit.# * c * 14 should do the trick.Before entering service mode to clear the error make sure the machine is in "Copy" mode
Need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
