20 Most Recent Sharp AR-C160 Color Copier Questions & Answers
2answers
Error Code
go to service mode then cancel it after that switch it off for 5 seconds then turn the machine on again
11/23/2018 6:23:54 AM • Sharp AR-C160... • Answered on Nov 23, 2018
2answers
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
7/29/2014 6:46:49 PM • Sharp AR-C160... • Answered on Jul 29, 2014
What does it mean to get this code E000
heater unit fails to reach certain temp try this (COPIER>FUNCTION>CLEAR>ERR) other wise check lamps and thermister
7/2/2014 5:39:54 PM • Sharp AR-C160... • Answered on Jul 02, 2014
How to fix a H5-02 code on a Sharp AR-336
input C + interrupt + 0 + interrupt +start +14 +start
12/26/2013 3:15:58 PM • Sharp AR-C160... • Answered on Dec 26, 2013
SHARP MX350N . ERROR CODE H4-01
You might Google the manufacturer and the error code to find a solution. If you have an owners manual, I would check there first to find how to solve the problem. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section. You also might also enter the "menu" on the printer if there is one, and discover whether you can solve the problem there.This is just a shot in the dark and and I would try the owner's manual first, but after all other options have failed, and if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself to factory default settings which might solve the problem. You will loose any settings and any work in progress. Just a guess. Good luck.
11/11/2013 8:32:26 PM • Sharp AR-C160... • Answered on Nov 11, 2013
I have problem sharp mx2300n everytime sign replace usedcontainer
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
3/2/2012 3:49:57 AM • Sharp AR-C160... • Answered on Mar 02, 2012
Copier problem - service code F1-70
F1-70 is communication trouble between the machine and the sorter finisher. Check the cables connecting the copier and the finisher and power off and on machine. Should clear the code. If problem persists, may need a new board.
I would also check the ground between the copier and finisher.
Don't forget to rate your answers, please!
11/15/2011 11:27:06 AM • Sharp AR-C160... • Answered on Nov 15, 2011
I am stuck here on
H5 .1continuous POUT not-reached error
8/18/2011 10:11:22 AM • Sharp AR-C160... • Answered on Aug 18, 2011
We have a sharp AR
H5-01. 5 Continuous POUT not-reached error
perform the following procedure to enter the simulation mode.
#-interrupt-c-interrupt-14-ready key
8/18/2011 3:55:07 AM • Sharp AR-C160... • Answered on Aug 18, 2011
Sharp .call for service Code
fuser problem
6/13/2011 6:51:11 PM • Sharp AR-C160... • Answered on Jun 13, 2011
Canon ir3170ci - error e000008-00001
This is a fuser roller life error. The machine has an internal counter that counts parts' usage. This code can only be reset by a technician.
10/10/2010 3:23:05 AM • Sharp AR-C160... • Answered on Oct 10, 2010
H5-01 code comes on when I turn the machine on.
This code means that you had 3 or more jams at the heat rollers that weren't removed. The machine had to protect itself and locked you out because more paper jams in this area will cause damage to the fuser unit. Inspect and remove the paper jams. Press these 4 buttons within 4 seconds P * C * it will ask for simulation number, enter 14 and press the black and white copy button, follow on screen instructions. if i remember it says execute and the copier will restart.........you may have to press the CA key to exit simulation mode.
7/18/2010 8:03:10 PM • Sharp AR-C160... • Answered on Jul 18, 2010
Where is the hd
Attached to the main board in a metal box accessible from a panel in the back of the printer.
6/18/2010 5:18:06 PM • Sharp AR-C160... • Answered on Jun 18, 2010
Error code L4-05 for Sharp AR-C160 Digital
main motor lock detection
shifter motor trouble
5/24/2010 12:26:00 PM • Sharp AR-C160... • Answered on May 24, 2010
Sharp AR-C160 Color Copier Logo
57 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
code use claer code h4 01
  • Office Equipment & Supplies
