20 Most Recent
Daewoo DTQ-20N2FC TV Questions & Answers
Pix flickels and gets small then normal and click
Bad caps in the power supply section (look for bulged and/or leaking capacitors) or dirty contacts on the main power relay (if it is an older CRT type) are the most common causes of those symptoms.
4/2/2014 9:25:15 AM •
Daewoo...
Answered
on Apr 02, 2014
REMOTE IS NOT WORKING NEED
The original is no longer available. The only choice you will have is to purchase a universal remote control. You can pick them up at most electronic retailers and also places like CVS, Good luck : )
7/25/2011 3:48:06 PM •
Daewoo...
Answered
on Jul 25, 2011
I Have A 1998 Daewoo
If you unit don't have RCA (push on jacks), then you will have to buy a RCA to coaxial converter box.
1/21/2011 5:43:09 PM •
Daewoo...
Answered
on Jan 21, 2011
Tv not powering up
What voltage is present at the collector of the horizontal output transister? If the same 102 volts then you have no horizontal drive.
12/11/2008 6:20:28 PM •
Daewoo...
Answered
on Dec 11, 2008
Diagrama tv dw19tt daewoo
I think it uses the 150 common chassis motherboard.
https://www.manualslib.com/manual/2480552/Daewoo-Dlt-19w4.html
Daewoo cm905s no audio?
There could be a few potential problems if your Daewoo CM905s isn't making any sound. Make sure all the cables and connections are tight first. If it doesn't work, ensure sure the audio source is not muted and that your speakers are active. Replace the audio source or speakers if the issue is still not fixed.
Help my daewoo start button doesn't work all the rest do what is wrong please .
It is difficult to determine the exact cause of the problem without first inspecting the vehicle. A few possible causes could be a faulty start button, a faulty dashboard control module, a bad ignition switch, or a problem with the wiring around the start button. An auto mechanic should be consulted to diagnose the exact cause of the problem.
My daewoo tv suddenly turn black and power off
the rear of all TV has a sticker label with model.
like xya50zzz123445
50 " TV
yes send it to a shop.
seems the PSU is bad, or overloaded an that takes tests and meters to find. and service manual .both and skills
take it to a shop is always best. or go broke guessing
NECESITO LOS CODIGOS PARA TV DAEWOO DE UN CONTROL UNIVERSAL RCA414BHZ
no hay in el folio? Es possible que no hay para este especifica Tele... pero pueden investigar en otro conrol universal de RCA....possiblemente 0130 0004 0009 0100 0005 0138 0043 0140 0039 0252 0279 0444 0080 0042 0058. Utiliza cada una, hasta ver si una funciona... Bueno suerte
