20 Most Recent
Daewoo DV-6T834 DVD Player/VCR Questions & Answers
After inserting dvd in player it reads no disc
Unfortunately , Some DVD players cant read some DVD s and then it gives either "loading" or " no disc"..reading on the display...
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just
to make sure that such DVD is ok ,you can try to run them on your
laptop.If the disc itself has problem, laptop does not read either..
Just in case,quick remedy ,pls Clean your DVD player's LASER lens .. A clean DVD player Lens ensures that
your DVD disc would be read properly. Unfortunately, your DVD player's
Lens accumulate as much dust and lint as the other parts of the DVD
player. There are many available DVD lens cleaner kits
that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD
- This cleaner contains six soft brushes that gently remove dust, dirt
and other airborne contaminants from your DVD player's lens. (Price:
$6.09)
Maxell DVD-LC DVD Lens Cleaner
- This DVD Lens cleaner features the "Thunderon Brush System" and
include tests for audio performance including Dolby 5.1 surround sound.
It also features an interactive on-screen instructions in 8 languages
including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner
- This DVD Lens Cleaner features an 8 brush carbon-system with carbon
edge that removes static build-up from your DVD Players. It prevents
skipping and also improves the sound and picture output of your DVD
Player. ($13.11)
if this remedy does not help and if your set has
still under warranty ,consult to service they may replace the LASER Reader
EYE...most of the time Laser Eye malfunctions and does this..
if it is not under warranty ,never ,never have someone repaired it..go buy a new one,It will be cheaper.. ...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
My Phillips DVD/VCR has no
Please let us know the complete model number of the VCR.
If your VCR does not have an output socket to connect the coax cable, you can connect it to the television using the AV cable. (
See attached image)
Connect the AV cable to the AV-Out socket of the VCR and connect the other end to the AV-IN socket of the television.
Hope this solves your problem. For more help and clarifications, please feel free to reply to this post with the details.
Thanks for using
FixYa.
Dvd player says "no disc"
Could a foreign object have been inserted into the tray? I have seen labels peel off and stick inside the mechanism, preventing it from reading the DVD. Also try unplugging it from the wall, let it sit for a few minutes (for the logic circuits to reset) then plug back in. Just turning it off does not reset the logic...
Dvd wont play just spins
Usual suspects (I have seen each one of these):
1. Home-made DVD defective
a- bad blank
b- bad burn (software settings incorrect)
c- not finalized
d- bad DVD recorder
2. Commercial DVDs - very scratched near center hole where startup data lives
3. Dirty laser lens on DVD player
4. Bad circuitry in DVD player (repairs almost always cost more than a new player)
Diagrama tv dw19tt daewoo
I think it uses the 150 common chassis motherboard.
https://www.manualslib.com/manual/2480552/Daewoo-Dlt-19w4.html
Daewoo cm905s no audio?
There could be a few potential problems if your Daewoo CM905s isn't making any sound. Make sure all the cables and connections are tight first. If it doesn't work, ensure sure the audio source is not muted and that your speakers are active. Replace the audio source or speakers if the issue is still not fixed.
Help my daewoo start button doesn't work all the rest do what is wrong please .
It is difficult to determine the exact cause of the problem without first inspecting the vehicle. A few possible causes could be a faulty start button, a faulty dashboard control module, a bad ignition switch, or a problem with the wiring around the start button. An auto mechanic should be consulted to diagnose the exact cause of the problem.
My daewoo tv suddenly turn black and power off
the rear of all TV has a sticker label with model.
like xya50zzz123445
50 " TV
yes send it to a shop.
seems the PSU is bad, or overloaded an that takes tests and meters to find. and service manual .both and skills
take it to a shop is always best. or go broke guessing
NECESITO LOS CODIGOS PARA TV DAEWOO DE UN CONTROL UNIVERSAL RCA414BHZ
no hay in el folio? Es possible que no hay para este especifica Tele... pero pueden investigar en otro conrol universal de RCA....possiblemente 0130 0004 0009 0100 0005 0138 0043 0140 0039 0252 0279 0444 0080 0042 0058. Utiliza cada una, hasta ver si una funciona... Bueno suerte
