20 Most Recent Cyberhome CH-LDV 700B Portable DVD Player Questions & Answers
2answers
Reads Disc but won't play disc-
Try using a cleaning disk.
7/6/2019 2:35:52 AM • Cyberhome CH-LDV... • Answered on Jul 06, 2019
2answers
CH-LDV700B need a battery for it
Jeanne, links below ,where to get batteries to show your appreciation press the helpful button and follow me on fixya for more tips and info. Battery Buyer Batterybuyer com Amazon ca battery replacement Portable DVD Player Batteries from Canada Portable DVD Player Batteries Ultralast Lithium Ion Universal Portable DVD Player Replacement Battery...
2/15/2016 3:42:05 PM • Cyberhome CH-LDV... • Answered on Feb 15, 2016
0answers
0answers
Repair
ch 700
7/29/2013 3:12:33 AM • Cyberhome CH-LDV... • Answered on Jul 29, 2013
Portable DVD Player Model No.
When you get the dreaded Disk Read Error, it normally occurs for one of two reasons. Either dust has built up on the lens of the laser mechanism, or the operating voltage of the laser has drifted off slightly due to heat and age. Of course, occasionally there are actual failures of components, which cause this, but these are the main two reasons.
Tools required by this guide are (not all are required for all parts however):
1) A normal sizes star (Phillips) screwdriver.
2) A very small Phillips screwdriver.
3) A small, flat screwdriver.
4) Some isopropanol alcohol (IPA)
5) A few cotton buds
6) A little mechanical grease. (I've used Vaseline before)
7) A can of compressed air.
8) An oscilloscope.
Cleaning the laser lens
1) Remove any CDs from the unit and unplug all leads and memory cards. Turn the unit upside down and use the small, flat screwdriver to pop out all the little plastic and rubber screw covers.
2) Take your normal sized Phillips screwdriver and unscrew all the screws.
3) Try to write down where each part comes from (including the screws as they have to be returned to the same location at the end. Stick them in a tub to keep them safe.
4) Turn the unit back up the right way, holding it all together. Place on the work surface and gently ease the case open. You may have to tilt the lid slightly towards the front, and slide out to avoid the CD tray. BE CAREFUL not to damage the eject/power button ribbon cable, as these are very fragile.
5) Remove the 4 tiny screws from the cd drawer top, being very careful not to cause any damage.
6) Gently lift off the lens casing and you will see the slide tray underneath.
7) To remove the slide tray you have to remove the two small screws, which are on the left hand side of the tray.
8) Gently pull the tray away from the rest of the unit by carefully sliding it all the way to the front until it has cleared the lip on the right of the tray. Look for any damage or wear, as this could be a cause of the unit malfunctioning. If you have compressed air give a few little squirts to any places, where you see dust, but you must be careful not to damage the laser lens.
9) Take a cotton bud and careful place some of the alcohol on it (but not so much that it is dripping everywhere). This alcohol is the same (or similar) to the small bottle of alcohol which is in audio and video cassette cleaning kits. This is probably the best way to locate a source. Locate the lens (the circular glass part) and very gently rub the cotton bud around the lens in circular motions for about 30 seconds, being very gentle. Once done, flip the cotton bud over and dry the lens with the other end for about 10 seconds.
10) The laser part slides on rods to reach different rings of the cd. These can become clogged up with dirt and dust, making movement difficult. So, take a clean cotton bud and clean the slide rods thoroughly, making sure you get to all parts and give a good clean.
11) The spin rod controls the movement of the laser and is greased to allow smooth frictionless movement. Clean the surface of the spin rod. If you have some grease to replace with then remove all the dusty grease (or as much as you can) and then apply some fresh grease. If you have no grease to replace with then just remove any excess dirt but try to leave a little grease, as it is required for the mechanism to work.
12) Clean the little cogs too so that all possible avenues are covered.
13) You have now completed the cleaning process. This often cures read errors and should always be attempted first. Reverse the dismantling process and put the machine back together, making sure you DON'T TRAP the eject / power button ribbon cable, as this can cause serious problems for you if it happens.
Hope this will help to solve the problem...
9/17/2011 9:52:55 PM • Cyberhome CH-LDV... • Answered on Sep 17, 2011
I need the left hand
There is no thing as a left side piece to a LCD panel,you need a new pan , or you have a bad driver board, or bad connectiond from ribon cable.
7/7/2011 7:23:52 PM • Cyberhome CH-LDV... • Answered on Jul 07, 2011
The battery is not charging.
that indicates that your battery is already damage try use other battery or try to replace it.
7/7/2011 3:22:55 PM • Cyberhome CH-LDV... • Answered on Jul 07, 2011
The cable that connect the
Try Sears parts dept.
6/10/2011 11:03:10 PM • Cyberhome CH-LDV... • Answered on Jun 10, 2011
The white piece of plastic attached to the rail so
This is something you'd have to contact the manufacturer for,
Though in all honesty it would be cheaper to just buy another portable player.
5/19/2011 10:36:42 PM • Cyberhome CH-LDV... • Answered on May 19, 2011
My cyberhome Modle ch ldv 7008. I have had this
If it has been sitting in a cupboard not used for that long there is a very good chance the batteries are no good. Try putting it on charge for a few hours but if it still doesn't work then it will probibly need new batteries. Is it the correct charger for the unit as the voltage may be incorrect also if it is then that will also be a problem.
7/18/2010 7:23:38 AM • Cyberhome CH-LDV... • Answered on Jul 18, 2010
Cyberhome CH-LDV 700B Portable DVD Player Logo
87 questions posted
Top Cyberhome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Cyberhome Televison & Video
Most Popular Question
dead battery
  • Televison & Video
