20 Most Recent Vizio E420VO 42 in. LCD HDTV Questions & Answers
Vizio e420ao tv, Little power light comes on the fades out, no pic, no power
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
1/3/2017 6:46:58 AM • Vizio E420VO 42... • Answered on Jan 03, 2017
Vizio HDTV doesn't power on...
Disconnect the power and let it remain shut down for 5 minutes. Reconnect power. See if this resets the system.
7/2/2016 9:30:22 PM • Vizio E420VO 42... • Answered on Jul 02, 2016
Why is it dark in the center?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
4/12/2016 4:26:19 PM • Vizio E420VO 42... • Answered on Apr 12, 2016
Blank screen when turn on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
1/18/2016 7:43:17 PM • Vizio E420VO 42... • Answered on Jan 18, 2016
4answers
My e420vo vizio wont turn
Did you ever find out what was wrong? This happened to me just now!
1/9/2016 2:35:01 AM • Vizio E420VO 42... • Answered on Jan 09, 2016
0answers
WHATS WRONG WITH MY TV? WHEN I PLUG IT IN IT SMELLS LIKE SOMETHINGS BURNING AND WONT TURN ON
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
5/12/2015 6:45:40 AM • Vizio E420VO 42... • Answered on May 12, 2015
A plugged in power adapter cord for a roku (hdmi) stick was accidently plugged into the usb port of my Vizio E420vo TV and the set died. It will not power back on at all now. I replaced the power supp
Might what to call the manufacturer and ask for help. It's sounds like a problem that they can answer.
2/14/2015 1:04:06 AM • Vizio E420VO 42... • Answered on Feb 14, 2015
No signal on vizio then screens turns purple
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
8/11/2014 5:04:36 AM • Vizio E420VO 42... • Answered on Aug 11, 2014
Find front/rear neck stand visio e260mv?
I would suggest EBay, as painful as it is to recommend them!
6/10/2014 11:17:13 PM • Vizio E420VO 42... • Answered on Jun 10, 2014
0answers
Tv turns on then I could see the vizio logo on screen then it shuts down
Power Supply problem. Have someone check Capacitor.
1/18/2014 7:07:05 PM • Vizio E420VO 42... • Answered on Jan 18, 2014
My volume keeps turning up full blast and will not go down
Probably bad or stuck tact switch for volume up.
12/4/2013 3:14:06 PM • Vizio E420VO 42... • Answered on Dec 04, 2013
Vizio E420VO 42 in. LCD HDTV Logo
66 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
  • Televison & Video
