20 Most Recent
Samsung UN65C8000 TV Questions & Answers
Un65c8000
Is this a Samsung TV? Can you post a picture of the distorted screen?
4/18/2014 12:37:46 AM •
Samsung...
Answered
on Apr 18, 2014
TV does not turn on, has continuous clicking sound
Check for any short circuited component/s at its main board.If you wish to get some details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic / Timeslide / Flipcard, can be
selected by the
drop-down list, at the top left of the display window,
will make surf easy. You can also do a
search, by type in the
brand name / model number / IC used, in the
search box at the top right of the display window.
11/11/2013 9:14:19 AM •
Samsung...
Answered
on Nov 11, 2013
My new Samsung UN65C8000 LED TV has an
You did not say if the first one went back for the same fault. If it went back for a different fault then this set is faulty! If not then unless it it more susceptible to RF interference possibly mains borne than the flawless set (that is possible) and you have some other equipment in the house which is radiating like a power supply or dimmer or whatever, it must be faulty. Turn everything in the house off just to be sure nothing is causing interference. Even then it could be picking up interference from elsewhere. What affects it or does it seem random (position time of day etc.)? The only way to be truly sure is to try it in another location
If it's new why not return it?
2/16/2011 1:08:36 AM •
Samsung...
Answered
on Feb 16, 2011
Samsung 5 blink code
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
10/27/2017 12:21:54 PM •
Samsung UN...
Answered
on Oct 27, 2017
Samsung LCD TV UN55C7000WF will not turn on
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Led tv will not power on
Secret menu ? If you mean factory setup menu then might have to replace the digital main . When in that menu you have to be careful or its replace the board time !
How can I fix a 3/4 inch vertical black line on my Samsung UN60D8000?
When liquid drips onto the x buffer boards (located along the bottom edge of the display panel ) the liquid Will damage the ribbon cables that are connected to the display panel. Replacing the display panel may be the only way to repair the tv. I've been in the tv repair business for over 30 years.... Dan
