20 Most Recent
Acer Aspire 3623WXCi Notebook Questions & Answers
My laptop can't detect wireless network in my
Probably, it is disabled. Try Fn F4. F4 shud have the WIFI logo if not find the F keys that has the WIFI logo. Or there is a switch on one of sides of the laptop which can be turned on.
Where is launch key 5 on acer aspire 3623WXCi
Are you sure it has bluetooth because some Acer computers have a button for it but don't actually have the hardware.
To check go to the control panel and search for a device manager.
Once you open that look if there is a bluetooth device and whether or not there is problem with it.
Turn on your computer and wait for Windows to fully boot.
Then log in as an administrator. You will not be able to use Bluetooth under a non-administrator account.
Press the button with the Bluetooth symbol on the left side of the computer. This will launch the Bluetooth utility. From here you can sync and manage Bluetooth peripherals.
Press the Bluetooth button again to disable Bluetooth. This will disable all connections, but the utility will save your settings so the same devices will sync with the computer again when Bluetooth is re-enabled.
hope this helps
Acer i cant change my profile picture in badoo
for example I have 15 pictures to choose for profile picture in my album,and when I delete that picture who was on my profile pic badoo automatic takes next picture who was next to deleted picture,so I put picture which I want next my profile picture and when I deleted pic. I got my favorite picture for profile,and after that I was add again that picture which I was deleted and she is in album again :D (with mouse you can sort picture how you want),so with mouse you can put favorite picture in front of existing profile picture and when you delete that existing picture you favorite automatical set for profile picture
The battery is not recharging
Possible that the battery is bad or weak, the adaptor is not outputing the required voltage or is faulty or that the charging circuit is faulty in the motherboard.
In all these you need to check on the voltage incident on the battery terminals. So connect the adaptor an check the voltage at the battery terminals in the laptop, if absent check at the pins, if absent check on the adaptor circuit.
check this link;
http://www.fixya.com/support/r5164850-laptop_power_supply
If voltage is present then the battery is a suspect, if not the motherboard charging circuit has problems if adaptor is good and there is no charging.
Need a new monitor i have aspire one d255e-13808
I found this on on this link:
http://www.ebay.com/itm/NEW-14-1-WXGA-LCD-SCREEN-ACER-ASPIRE-3623-3623WXCI-/200639574561?pt=LH_DefaultDomain_0&hash=item2eb70cf221
Please let me know if this washelpful and if it solved the problem! Also if the information provided washelpful, please click on the appropriate thumbs to make us aware that theproblem has been corrected or that the information provided helped you with theproblem.. Thank you and Good Luck.
How do i access the webcam on the acer aspire one?
Any software that supports webcam such as video calls, video conferencing, skype, yahoo messenger, etc..but before that make sure the driver for your webcam is properly installed. Operating System usually install default driver for that but just to be sure go to acer website search for the particular model in their support page
How to activate my Windows 7 Home Premium OS
You can activate either online or by phone. To activate online you need an Internet connection. Activating by phone requires interacting with an automated phone system.
To activate Windows:
Open Windows Activation by clicking the Start button , right-clickingComputer, clicking Properties, and then clicking Activate Windowsnow. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
You can then select the method you want to use to activate.
Acer aspire 4750g
I cannot access my webcam. I'm
start>right click computer>manage>devices> check to see if there is a yellow exclamation mark beside your camera device.
start>all programs> windows update - make sure that the computer has been fully updated.
restart computer after updates. if camera still does not connect uninstall driver and download driver from website as previous version might be corrupt
