20 Most Recent
Coby DVD-224 DVD Player Questions & Answers
Universal Remote Control
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately,
Coby is a company whose electronics cannot be controlled by any remote
other than the one that came with it. This means there is no code
available for universal remotes. If you need a replacement remote (it
will be identical to the one that came with the unit) please call our
customer service number above. They will take your information and
provide you with the procedure for ordering a part from Coby.
If
you feel this solution doesn't deserve a good rating, please let me
know why so that I may better assist you. If there is anything more I
can do to help, I will!
How can I find/reset passwords on Coby 224S and Coby 206
http://www.dvddemystifiziert.de/codefree_en/coby.html
Unfortunately, I don't see Coby 206. There is a 207 however if that would work.
Unlock Coby DVD players - DVD hack
Coby DVD-201 / DVD-217 / DVD-224 / DVD-227 / DVD-237 / DVD-505 / DVD-514 / DVD-527
- Press SETUP
- Press VOL+, VOL-, VOL+, VOL-
- Current RC should be displayed
- Select the RC with RIGHT and LEFT (255=Codefree)
- Press SETUP
- Turn the player off
Coby DVD-202 / DVD-203 / DVD-207 / DVD-208 / DVD-218 / DVD-507 / DVD-508 / DVD-606 / DVD-615
- Method 1:
- Press SETUP
- Press 2, 1, 8, 8
- A new menu entry appears (Version)
- Select it
- Press ENTER
- Select "Region" with RIGHT
- Select RC with UP, DOWN (0 = codefree)
- Press SETUP
- Method 2:
- Press SETUP
- Press SETUP
Remote code for phillips dvd 711
I hope this helps
You need an OneForAll6 remote (URC 7560)
- Press DVD device button (set remote to DVD)
- Press and hold MAGIC until it flashes 2x
- Enter Setup Code (0539)
- Press MAGIC again
- Enter 085
- Enter 222 222 005 255
- (should be displayed)
- Press PLAY
Dvd player door does not open
Check to see if anythig is blocking the tray from opening. Also the tray motor or connections may be failing. I would open the case, remove and replace as many connections, one at a time, to make sure the connections were good. If the tray still does not move, then one or more than one component has failed. It could be an electronic component or the motor.
