20 Most Recent Craftsman Sears 139.18190 18190 Compatible 315 MHz Mini Key Chain Security Remote Control Questions & Answers
2answers
Garage door won't close when it's cold outside
Control board has thermal issue. Bad solder joint that contracts when cold could be the culprit. Take out board and carefully resolder every ****** connection on board.
4/3/2019 9:08:10 AM • Craftsman... • Answered on Apr 03, 2019
The opener on the wall just make a sound but the door won't go up or down
You have a gear kit broke.
6/8/2015 7:56:54 PM • Craftsman... • Answered on Jun 08, 2015
!/2 hp craftsman garage opener is closed and when you push to open it tries to close.
Your limits are damaged. Will need to replace the limit switch.
1/20/2015 8:34:53 PM • Craftsman... • Answered on Jan 20, 2015
Garage Door Opener
Adam, I don't know how old the GDoor opener is but if it has served you for long time, it's asking for retirement. These days brand new units are cheap and will give you many years of trouble free use.
4/23/2014 10:29:44 PM • Craftsman... • Answered on Apr 23, 2014
Problem with craftsman garage door opener
That is a two-flash code. It means either the wires to the safety sensors have a short in them, or one or both sensors are wired incorrectly at the motor unit. What you describe sounds like there may be a break in the wire, and the door causes the tracks to move just enough to open that break in the sensors. There could be a staple through the wires causing a short (I've done that when using a staple gun), and that could be your problem. Check your sensor wires from the motor down to the sensors themselves, and be sure they have a little bit of wiggle room. If you find a staple or something has cut the wires and caused a short, you can separate the wires a bit, and wrap each side separately with electrical tape.
9/20/2013 7:31:23 AM • Craftsman... • Answered on Sep 20, 2013
Sears garaage door remote
What exactly is the problem with the remote?
4/22/2013 2:51:56 PM • Craftsman... • Answered on Apr 22, 2013
How can i open my craftsman 315 garage door opener with a broken remote?
you might have a power failure. can you still use the wall unit?
4/2/2013 8:02:37 AM • Craftsman... • Answered on Apr 02, 2013
2answers
Coromaster B2B Garage Door Opener. It only opens the door halfway?
Question edited for clarity. This is an older model. Either the weight of the door is borderline for the motor and that is why it is beeping. The counterbalance system need adjusting. Or the carbon brushes on the motor need replacing. You can also try lubricating every single item that moves and the tracks to reduce rolling and sliding resistance. Use proper garage door spray or light machine oil not WD40 which goes waxy / gummy after a couple of months. https://www.google.com/search?q=Coromaster+B2B+garage+door+opener and https://www.google.com/search?q=Coromaster+B2B+garage+door+opener+opens+halfway and Beeps https://www.google.com/search?q=Coromaster+B2B+garage+door+opener+motor+beeps ..
4/19/2024 7:51:17 PM • Building... • Answered on Apr 19, 2024
Genie Garage Door RC Receiver. Where is the learn button for Genie receiver model OHDH390 please?
Question edited for clarity. It doesn't look like that model number is correct 390 is the frequency of the signal. It is mentioned here are part of the regulatory approval process as a much longer number https://fccid.io/B8QOHDH390 The Learn Button is next to the bulb https://www.geniedoor.com/support/programming-instructions/garage-door-opener-remote-programming/ More here https://www.geniedoor.com/support/programming-instructions/ https://www.google.com/search?q=genie+receiver+ohdh390+learning+manual ..
4/8/2024 12:29:27 AM • Building... • Answered on Apr 08, 2024
I have a Novoferm 553 garage door system. The remotes have stopped working.
Sounds to me like a cold solder joint on one of the boards
3/31/2024 1:13:56 PM • Building... • Answered on Mar 31, 2024
How many sand and stone and cement do you need or cubic meter of concrete
A concrete mixture ratio of 1 part cement, 3 parts sand, and 3 parts aggregate will produce a concrete mix of approximately 3000 psi. (20685 kpa)
3/25/2024 5:28:07 PM • Building... • Answered on Mar 25, 2024
My DTS 600 garage door open and close very slowly
Unlikely your garage door is battery operated. The remote and wall unit yes. The remote just tells the mains operated motor to get turning. The issue will either be that everything that moves needs lubricating, motor spindle, pulleys, chain, tracks and pivots, or the carbon brushes in the motor need replacing. https://www.google.com/search?q=DTS+600+garage+door and how to fix https://www.google.com/search?q=DTS+600+garage+door+opens+slowly ..
3/13/2024 5:23:31 PM • Building... • Answered on Mar 13, 2024
How do I fix an exterior mobile home door that's not lining up properly?
Question edited for clarity. Question moved from Cars and Trucks category. Look at the corners of the doors that hold the aluminium frame together and if it is a modular door, tighten them up. If it is a solid door, adjustment can be made by shimming behind the bottom hinge with a piece of cardboard. This will move the bottom out and up. ..
2/18/2024 9:28:00 PM • Building... • Answered on Feb 18, 2024
2answers
I have roller door opener merlin430R. I can not
Look at this video, it should answer your question. The learn button in under the green button. Remove the green button. http://www.youtube.com/watch?v=7CqMy2UfG9k
2/15/2024 10:23:37 AM • Building... • Answered on Feb 15, 2024
Garage door opens too far and ends up 2 or 3 inches into the motor housing. How do I fix this issue.
Check the opening limit dial on the garage door opener unit. You can locate the dial that controls the opening limit on the opener unit and use a flat head screwdriver to turn the dial counter clockwise until the door stops about an inch and a half away from the stop bolt. Then, test the door and make sure it does not slam into the bolt. A video tutorial on how to adjust the opening limit of a Craftsman garage door opener is available on YouTube. If the above step does not work, check the limit switches on the garage door opener. Most garage door openers have limit switches that control how far the door opens and closes. Improperly adjusting these switches can cause the door to stop halfway. Consult your garage door opener's manual to learn how to adjust the limit switches. Make small adjustments until the door closes fully. Craftsman garage door opening too far and hitting stop bolt easy adjustment (youtube.com)
1/15/2024 10:16:07 PM • Building... • Answered on Jan 15, 2024
tip
NHK Tiling
At NHK Tiling, our tiling process has been perfected over the years to give you the best results possible. Our Expert Tiling Service is perfected for a range of applications, styles and functions. Whether you require contrasting grout to make a statement with your kitchen splashback, or you need a Professional Tiler for tiling your swimming pool, NHK Tiling is the ideal choice for you. https://www.nhktiling.com.au/
on Dec 06, 2023 • Building Materials
tip
Granite Warehouse
GRANITE WAREHOUSE is a privately owned Western Australia business specializing in the wholesale of Granite, Marble, Limestone, Sandstone and our line of engineered stone, Stellastone, in slab form suited for the fabrication of kitchen and vanity benchtops as well as other building uses. Granite Warehouse was founded in 1995 by Tindaro (Tony) Tomeo to fill a need in the local Western Australian market for quality natural stone. With more than 40 years experience in the building industry, specializing in cabinet making and kitchen fit-out, Tony, with wife Susan and son Mark, built Granite Warehouse into the well-respected business it is today. With Tony and Susan's retirement, and in the best family tradition, Granite Warehouse has been taken over by Mark Tomeo who continues to develop the business to fill best the needs of those wanting to enjoy the beauty of stone installed to their home or business. https://granitewarehouse.com.au/
Craftsman Sears 139.18190 18190 Compatible 315 MHz Mini Key Chain Security Remote Control Logo
1 questions posted
Top Craftsman Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Craftsman Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • Craftsman Building Materials
Most Popular Question
door closes only holding control button
