http://majorgeeks.com/FreeUndelete_d4407.html
FreeUndelete restores deleted files, including those removed from Windows Recycle Bin. In case of accidental removal of files on a NTFS (1.0 and 2.0) (default for Windows Vista , XP, 2000 and NT), FAT32, FAT16 or FAT12 file systems this is the utility to help. Supported file systems: NTFS 1.0, NTFS 2.0, FAT12, FAT16 and FAT32 The recovered files are saved into a new user-selected location to prevent overwriting the deleted files on the original media. hope this helps
If you are referring to a device not being able to connect through a usb port on a computerw7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
Hope it helps.
you will need to connect your camcorder to your computer
click start click on my computer to open from there you should see your camcorder then right click to select open you should see the data/files in there select what you want to delete right click select delete or you can right click select format this will delete all data on hard disk
hope this helps you
23 questions posted
219 Questions
98 Questions
89 Questions
50 Questions
61 Questions
