20 Most Recent Sylvania LC320SSX 32 in. LCD TV Questions & Answers
Sylvania hdmi port not working
Sounds like you may need a new main board.
1/28/2018 1:29:36 AM • Sylvania... • Answered on Jan 28, 2018
Just got a fairly new Sylvania lc32ossx from a
I believe you have to have a remote to set your picture to the right size. You can get a universal remote that is recommended for your television set.
7/4/2017 8:26:33 PM • Sylvania... • Answered on Jul 04, 2017
How do I get the sylvania lc320ssx codes for fios ?
0029,0022,0067,0038. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
8/7/2014 4:32:47 AM • Sylvania... • Answered on Aug 07, 2014
My 32 inch sylvania model LC320SLX is flashing
press up arrow then down arrow or left arrow then right should fix the problem iv had my tv do this twice and is how I fixed it but took me a while to find the fix both times so posting this here because this is the first result in my searches so hopefully if it happens to me again I can remind my self by helping everyone else
10/20/2013 9:18:09 PM • Sylvania... • Answered on Oct 20, 2013
0answers
0answers
Lc320sx
Be the first to answer 2/18/2013 4:02:45 PM • Sylvania... • Posted on Feb 18, 2013Be the first to answer
0answers
32 inch sylvania flashes red, blue, black, then
check the main power switch of the TV, then also check the control buttons on the front panel of the TV maybe one of the button s on the front panel is press (normally close state), or maybe the buttons is defective (maybe the menu button)
7/22/2011 2:18:54 AM • Sylvania... • Answered on Jul 22, 2011
THE SET TURNS OFF BY
Bad Capaciotrs on the Power Supply Board can do this ,they will be vented or swollen on Top.
7/5/2011 12:10:22 PM • Sylvania... • Answered on Jul 05, 2011
I need an owners manual
Free Manual Download at the link below.
http://www.sylvaniaconsumerelectronics.com/product/index.php?id=7
Please leave feedback.
Cheers
Andy
6/10/2011 7:55:57 PM • Sylvania... • Answered on Jun 10, 2011
Sylvania LC320SSX HDTV no longer
Required power supply board is available in shopjimmy.com
6/9/2011 1:10:42 AM • Sylvania... • Answered on Jun 09, 2011
How do you use tv as pc monitor
if it has a hdmi port then you can use it as a pc monitor,plug in the hdmi cable through your cpu or laptop then,select hdmi as your tv source
12/14/2010 7:32:26 AM • Sylvania... • Answered on Dec 14, 2010
Is it possible to cast/mirror/ etc. from ab android phone to a Sylvania TV manufactured in 2005?
No, because screen casting wasn't invented and it isn't a Smart television. Time for a new one.
3/11/2024 8:53:32 PM • Sylvania... • Answered on Mar 11, 2024
I have an old Sylvania tv and it won't turn on
Here are some troubleshooting tips to try. However, as it is an older set, if these tips fail, the cost of a repair at a shop might exceed the value of the TV. In short, a new TV may be in the works. Cross your fingers. One of these tips may work. Let's troubleshoot the issue and try to get it working: If you are using a remote, check the batteries in it. If you are using several remotes with it, try the alternative remote. Sometimes there is a glitch affecting the remote for a Roku where it won't turn on the TV other than a powered black screen and you have to use the other remote to turn it off and back on and then the Roku screen pops up. I have not sorted out why. Check Power Cord and Connections: First, ensure that the power cord is securely plugged into both the TV and the electrical outlet. If you suspect a faulty power cord, consider trying a different one. Reset the TV: While most Sylvania TVs don't have a dedicated reset button, you can perform a manual reset: Unplug the TV's AC adapter from the electrical socket. Press and hold the Power button on the TV for 20 seconds. Plug the AC adapter back in and turn on the TV. Check Audio/Video Cables: Inspect the audio/video cables connecting your TV to the satellite or cable receiver. Ensure that the color-coded prongs match their respective connecting points. Correct any mismatches (e.g., white cable into a red port) by reorganizing the prongs. Inspect Coaxial Cable: Look for the coaxial cable on the rear side of the receiver, attached to the port labeled as ANT IN. Confirm that the connection is firm; a loose coaxial connection can cause display issues. Tighten the cable by pinching the silver band on the end and rotating it clockwise until secure. Check for Interference: If distortion continues on the TV screen, consider nearby interference. Power-hungry appliances can cause electronic interference, affecting display quality. Visit a Repair Shop: If the above steps don't resolve the issue, you may need professional help. Some technical faults, such as a blown fuse or faulty capacitor, require expertise in dismantling and soldering. If uncomfortable with such tasks, consider visiting a repair shop
2/3/2024 6:17:20 AM • Sylvania... • Answered on Feb 03, 2024
2answers
I have a 37in limited edition Sylvania TV I have tried every code on my Phillips universal remote none work. Is there a specific code.
  1. Auto Code Search:
    • Turn on your Sylvania TV.
    • Press and hold the "Code Search" button on your Philips remote until the indicator light stays on.
    • Press the "TV" button on the remote to set it to control the TV.
    • Press the "Power" button repeatedly until the TV turns off.
    • Press the "OK" or "Enter" button to save the code.
  2. Manual Code Entry:
    • Find the code for your Sylvania TV in the Philips remote control manual. If you don't have the manual, you may be able to find it on the Philips website.
    • Press and hold the "Code Search" button on the remote until the indicator light stays on.
    • Enter the code using the number buttons on the remote.
    • Test if the remote now controls your TV. If not, repeat the process with a different code.
  3. Try Common Codes:
    • Some common Sylvania TV remote codes for Philips remotes are 0810, 1684, 1886, 2183, 1081, 1172, 1196, and 2049. Try entering these codes manually.
1/9/2024 10:32:14 PM • Sylvania... • Answered on Jan 09, 2024
Sylvania tv with vcr/dvd player. vcr tape keep being ejected even when using tape cleanser ejected
The most likely cause is a faulty mode switch.
12/12/2023 10:12:41 PM • Sylvania... • Answered on Dec 12, 2023
2answers
Flashing colors on Sylvania lcd TV
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
11/5/2023 2:26:58 AM • Sylvania... • Answered on Nov 05, 2023
Sylvania LC320SSX 32 in. LCD TV Logo
21 questions posted
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
set turns off
  • Televison & Video
