20 Most Recent
Archos Jukebox Studio 20 MP3 Player Questions & Answers
Upgrade Hard drive to Solid State Drive
Hard drive error
Same exact problem let sit for several months went to turn on and all i could see was a "hard disk error" message flash very quickly and then turn off. after months of no help online i decided to open.
My jukebox 20 and there are 4 ni-cad batteries inside. i removed batteries and replaced with 4 "AA"
regular energizer batteries and it works fine. at least until i extract my 1000 songs and put them on another device so i ll never lose them.
https://www.allhdd.com/solid-state-drives/
It shows disk error on screen and i can't software
You might have a bad hard drive in the device. The Jukebox 20 has a hard drive inside which stores the songs and if that has died, it would need to be replaced. Another possibility is the files got corrupted. When I figure out why mine is doing the same thing ... I'll post again with a better answer but I strongly suspect the little hard drive inside it.
Harddisk does not start
I have noticed when I charce my drive when it is fully charged it gets a drive error but after disconnecting the charger it operates ok!!
MY ARCHOS JUKEBOX STUDIO 20
check out the port in which internet is connected to the juke box and check out the internet settings to detect the fault.as you mentioned that you can use web-mail and its shows its connected that means the jukebox is connected properly but internet is not connected properly or the settings are not roper.
check out .keep updated.thanks.
Hard drive error
same exact problem let sit for several months went to turn on and all i could see was a "hard disk error" message flash very quickly and then turn off. after months of no help online i decided to open
my jukebox 20 and there are 4 ni-cad batteries inside. i removed batteries and replaced with 4 "AA"
regular energizer batteries and it works fine. at least until i extract my 1000 songs and put them on another device so i ll never lose them. GOOD LUCK.
Studio 20
me too but I dont use my archos what will ı do
Archos Jukebox 20
You just blew your unit! U might buy a used unit on ebay.Fixing this problem is alittle tricky.
