20 Most Recent
Apex Digital HT-150 System Questions & Answers
APEX DT250A digital box died
The Problem more often than not is with one or two of the electrolytic capacitors on the power board. They can be bought at Radio Shack for about $1.50 or less. You can tell if the Cap is blown by looking at the top.. it should be flat and have a x stamped in it.. if the top is cracked or "domed" the cap is bad. I just fixed one today for an employee. If you're not comfortable doing board level repairs, I suggest finding a friend. The repair took me a total of about 15 min. The Bad Cap was a 470uf 25v, but radio shack had a 35v one.. works just fine.
Converter wont work red light
If you're electronics savy, as in replacing capacitors, open it up.. that's your problem.. one or two of the caps on the power board has gone bad.. most likely a 470uf 25v, which can be replaced with a 470uf 35v found at Radio shack for about $1.29. You can tell if it's bad if the top is cracked open & leaking or just domed out instead of being flat.
Apex dt250 digital convertor-- light stays red and
flat.
Model dt 250 A will not turn on. Red on odd jewell
flat.
As far as the cc mode, I'm not sure, but this fix will get your box working
My converter box light wont
this is not the place where you would send it, you need to contact the people you bought it from. One thing though, when you get a new one, buy a power surge protector so that it won't burn out again.
The red light stay on
corrupt board maybe affected.. mainly its memory.. need to replace new board for that...some causes if you dont turn it of properly or either low voltage area
