20 Most Recent Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Questions & Answers
0answers
Picture is too dark and will not adjust brighter
reguletor supply input resistence hi valu
4/22/2017 1:55:16 AM • Apex Digital... • Answered on Apr 22, 2017
How I set up tv apex gb 5108
Se it up to do what?
9/23/2016 6:08:49 PM • Apex Digital... • Answered on Sep 23, 2016
0answers
Picture is going to like a 3D effect
try resoldering the convergence ICs often the pins on the ICs can develope a solder issue.
2/11/2013 9:52:30 AM • Apex Digital... • Answered on Feb 11, 2013
Clicking noise in the back of apex gb5108. but won't come on
Set is in shutdown because of a short
5/23/2012 1:19:26 PM • Apex Digital... • Answered on May 23, 2012
Hi, I own a
universal controls dont work well with this tvs to change channels you have to go up or down you cant select a channel because of the button on the original control it has to be put in how many digits you want the best thing is to order a new one
5/9/2011 7:29:19 PM • Apex Digital... • Answered on May 09, 2011
Wavy picture vertically
if you have the speakers on top of the television or a phone near it might becaused by this
2/23/2011 2:35:34 AM • Apex Digital... • Answered on Feb 23, 2011
The tv won't come on.
Here are some DIY steps that may help you fixing the problem.
  1. Check the power cord - check the cord it might be opened (no continuity).
  2. Check the internal fuse - sometimes the fuse fail by itself due to power surge, replacing with new one cure the problem. However if the fuse blew again then this is an indication that you have a shorted parts on the power supply. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
The next steps should be done by an expert or qualified technician because isolating the problem on the regulator section is technical.
But first check if the unit is under warranty then avail it because the manufacturer will fix it for you for free or a little charge only.
1/19/2011 10:02:17 AM • Apex Digital... • Answered on Jan 19, 2011
Apex gb55108 the convergence is bad ...shows
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
10/15/2010 3:20:09 AM • Apex Digital... • Answered on Oct 15, 2010
I have a black line acrossthe center of my apex
hi
it should be changed just
if any body want to repair, it may be to expand the problem
6/2/2010 7:21:54 PM • Apex Digital... • Answered on Jun 02, 2010
Screen Distorted
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
5/15/2010 4:44:43 AM • Apex Digital... • Answered on May 15, 2010
Just watching the set, and it turned into a "raindow"
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
4/17/2010 4:58:12 PM • Apex Digital... • Answered on Apr 17, 2010
Come up 3d how to change
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
4/3/2010 9:38:06 PM • Apex Digital... • Answered on Apr 03, 2010
Convergence toshiba 50a62
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
3/25/2010 5:11:15 AM • Apex Digital... • Answered on Mar 25, 2010
Replaced convergence ic's...still a converg on Apex GB5108
did you replace the low ohm feed resistors with the ICs?
3/11/2010 3:20:32 PM • Apex Digital... • Answered on Mar 11, 2010
2answers
I HAVE A APEX GB5108 MODEL 51
your convergance amps have gone south and need to be replaced have a tech do it there will also be a couple resistors blown not to expensive
1/29/2010 2:01:01 AM • Apex Digital... • Answered on Jan 29, 2010
Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
79 questions posted
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Apex Digital Televison & Video
Most Popular Question
own
  • Televison & Video
