20 Most Recent
Apex Digital AVL2776 27 in. HD-Ready LCD Television Questions & Answers
How do I contact APEX technition?
go to the setup option on remote and find caption options there. There will be a choice of CC1, CC2 and maybe a few more. just change it to OFF.
PROBLEM CON SOUND AND TV
Parece que su problema es solamente de configuracion fisica and programacion. Empesando conecte su cable al televisor y programe por el menu los canales que se van a recibir por el cable y no por una antena exterior. Sin el cable puesto y el televisor prendido y el volumen alta debes de poder escuchar sonido rasposo porque no hay imagen. Si acaso hace eso entonces tu televisor no tiene problem electronica y es como dije anteriormente. Buena suerte y dejame saber algo. Que Dios lo bendiga.
No power to tv when turned on
If there is no power at all, then it is either socket, power cord or PSU board. Check if the power plug is fused.If the TV stays in standby, then it is protect mode. In that case the TV is forced to standby because an internal problem has been detected. PSU and other internal parts must be tested and repaired.
TV shuts off by itself
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV
up(warranty was up of course) and found several bad capacitors.
Phillips and several other companies were sold capacitors that although
were highly rated failed within 5 years because of a lack of
preservatives. All sorts of electronic equipment is now being effected
due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Power supply keeps turning off
You may have answered your own question, if the power adapter is turning off It stands to reason that it is either over heating or has failed. Other thing that might be happening is your TV might have a auto reset switch that powers the unit down because another componet has already failed.. this keeps the unit from sustaining further damage... Good luck
I turn it on and then cut off. i have to do this
Sounds like a bad cap or two. Capacitors that are weak will work after they heat up. In many cases the cap can have a visual sign of being bad the top will be bulged. That is not always the case and then they have to be checked with a meter.
