20 Most Recent GE Security Simon Xt Wireless Control Panel 40 Zones Questions & Answers
Troubleshooting a GE Simon XT: Clear Errors and Alerts ...
? 3:06
https://www.youtube.com/watch?v=AtOCuthlsTo
Oct 3, 2011 - Uploaded by LiveWatch Security
Troubleshooting a GE Simon XT: Clear Errors and Alerts -Wireless Home Security ... Many times the Simon XT panel willbeep to indicate there is something ... How do you turn off the warning beep when you turn on alarm? I find it very useless and annoying. Can't seem to find a way to turn that feature off.
My Simon XT is beeping every 4 hours. How can I stop it ...
help.livewatch.com/.../20399861-My-Simon-XT-is-beeping-every-4-ho...
Aug 28, 2011 - If your panel has been beeping throughout the day and you want to turn off ... Scroll down on the Simon XT until you see "System Programming".Missing: control ‎hello ‎control ‎box
GE Security... | Answered on Jun 27, 2016
There are two tabs (and possibly a screw) on the top of the Simon XT panel. Remove srew (if installed) and press the two tabs, pulling forward. Front part of panel is hinged and will rock forward. Battery is located behind front half. It is a 6 volt 1.2 Amp Hour lead acid battery.
You must completely downpower the Simon XT (wall plug in and battery) then replace with new battery first, then reconnect wall power. Close the front panel and snap it closedand replace the screw (if it was installed).You will need to set the time on the panel, following the instructions in the users manual.
GE Security... | Answered on Jan 06, 2015
IT might be testing ok, but you need to load test it. It could be the charging circuit but in most cases the battery will show a surface charge that is ok for a short period of time.
GE Security... | Answered on Feb 10, 2014
Providing that you the outlet is putting out proper voltage, check the voltage output of the plug in transformer. Used a voltmeter set to AC and attach the leads under the plug in transformer (where the wire normally go) and plug back into the outlet. The voltmeter should be reading around 9 volts AC. If there is no a low or no reading, you have a bad plug in transformer. It can be replaced with a 9 volt AC 25 volt amp transformer. Battery may also have to be replaced, if it is depleted. If this does not fix the problem, you have a bad panel and it will need to be replaced.
GE Security... | Answered on Feb 06, 2013
If you open the panel (two tabs and possibly a screw on top) you have access to the back of the top portion. There should be a phone jack on the back with a plug inserted into it. DO NOT pull this plug yet! Trace the wire from the plug (either into the wall or down the wall) to a tan phone jack. Disconnect the plug from this end instead of the panel end and that should re-route your phones away from the house lines.
All wireless security motions have a 3 min delay built into them. This means that whether the alarm is set or not when the motion detector picks up motion it shuts down for 3 min and will not pick up motion. This is done to conserve battery power. So I always advise customers to arm the system and stay away from the motion for 3 min total. example: 60 sec to arm system + 2min wait time. then try to trigger motion. If this does not help and assuming batteries are good, you'll need to replace motion. Good luck. This may help https://al.ly/vR54zP
GE Home Security | Answered on Dec 15, 2019
I would start by power cycling your system. Remove the battery & power. After waiting 10 minutes or so reconnect the battery and then power. Other than that you need to be a bit more specific with your issues.
GE Home Security | Answered on May 03, 2019
Try disarming system twice to get the fire zone to reset. If that doesn't work, try to downpower the entire system, including back up battery then re-power the system with the back up battery first.
GE Home Security | Answered on Oct 24, 2018
First of all, here is the direct link to the ONLINE USER'S MANUAL for that model:
http://www.novisec.nl/cms/component/option,com_docman/task,doc_view/gid,67/
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
See page 17 of the ONLINE USER'S MANUAL for detailed instructions on how to reset the unit to default settings. Basically it says:
Push the MENU button, select admin and enter 3477 for the password, then press OK to confirm.
Use the arrow keys to navigate to UTILITIES, then press ENTER.
Then navigate to RESTOREPARA and press ENTER.
Then select OK to confirm and the system will automatically reboot.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
GE Home Security | Answered on Oct 08, 2018
Try changing batteries in both unit andbutton - a common cause for failure.
GE Home Security | Answered on May 08, 2018
you need to get the installer code, then enter programming mode to delete the sensor.
GE Home Security | Answered on Mar 28, 2018
They pick up signals from taxis and tow trucks. One some you can change the channels. Unfortunately the problem of 'wireless'.
GE Home Security | Answered on Jan 29, 2018
GE Security Simon Xt Wireless Control Panel 40 Zones Logo
14 questions posted
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
View Most Popular
GE Home Security
  • GE Home Security
Most Popular Question
seems beeping noise coming from
  • Home Security
