20 Most Recent Apple iPhone 3GS Black (16 GB) Questions & Answers
As for this kind of situation, you need to resort to Leawo iTransfer to manage your photos on iPhone. Just follow the below steps to do that.
Leawo iTransfer is third-party software which allows you to transfer, delete or add files among iOS devices, iTunes and PCs. And it supports about 12 kind of files like app, music, movies, photo and so on. You can easily transfer, delete and add your photos, music or other types of files among those iOS devices. Let's take the details about how to delete photos on iPod as an example to see how it works.
1. Connect your iPod device to a computer;
2. Open Leawo iTransfer;
Open iTransfer and it will detect your iPod device automatically.
3. Find photos;
Click "Photos" which is in the contents of "LIBRARY" of iPod and then choose photos you want to delete on the right side of screen.
4. Delete photos
Right click to choose "Delete" button to complete the deletion after you selected those photos.
This way makes you easily delete photos on different versions of iPod nano, iPod touch, iPod Shuffle and iPod Classic as well as other iOS devices. If you don't mind that those photos on your iPod touch will be deleted from everywhere, you can choose the first way to delete them. In the second way, you need to find the folders which are synced with iPod nano first and then use iTunes to complete the deletion and it is no doubt that this is a complicated way. And about the third way-Leawo iTransfer, I think it is the most convenient way to realize the deletion compared with the former two ways. What do you think?
For more details, check: How to Delete Photos from iPod
Apple iPhone 3GS... | Answered on Sep 09, 2019
iTunes and iCloud can help you. Just follow the steps in this post. How to Unlock iPod Touch
Apple iPhone 3GS... | Answered on Aug 21, 2019
"iPhone won't restore" is a common issue. However, there still are some ways to fix this issue. Follow below instruction to have a try.
1. Hard reset iPhone
Hard resetting your iPhone is not highly recommended, but it indeed works sometimes when your iPhone won't restore or gets stuck. Make sure your iPhone is plugged into your computer while performing the hard reset. And it should be noted that the hard resetting differs upon your models of iPhone.
2. Try to restore your iPhone in DFU mode
DFU stands for Device Firmware Update, and it's the deepest type of restore you can do on an iPhone. It's time to try a DFU restore if, after trying all the methods mentioned above, your iPhone still won't restore. This is a special type of restore that clears your iPhone's hardware and software settings, giving your iPhone a completely clean slate. Oftentimes a DFU restore will let you restore iPhones that are experiencing software difficulties that prevent normal restores.
3. Update iOS to the latest version
Check whether your iPhone has been running on the latest iOS. It's easy to do the check work: on your iPhone, open "Settings" app and then go to "General" option. Open the "Software Update" option on the "General" tab. Your iPhone will check if there is any iOS update available. Follow the on-screen notifications to update your iOS if an update is available.
4. Put your iPhone into recovery mode and set it up again
Sometimes your iPhone won't restore because iTunes doesn't recognize your iPhone, or your screen is stuck on the Apple logo for several minutes with no progress bar. In such situations, you could try to put your iPhone into recovery mode and set it up again to fix "iPhone won't restore" issue. The detailed operation will be discussed below.
If above methods don't work, check this post: 5 Methods to Fix "iPhone Won't Restore" Issue
Apple iPhone 3GS... | Answered on Aug 05, 2019
You can resort to iTunes to unlock iPhone without password. Just follow below steps.
To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
Method One: How to unlock iPad without password using iTunes
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
For more methods, check: How to Unlock iPhone
Apple iPhone 3GS... | Answered on Jul 04, 2019
Hi
What happens when you try to charge the device?Won't charge?Switch chargers.
Try hard resetting it and see what happens.Here's a video tutorial on how to go about it.
Hope it helps.Thanks
Apple iPhone 3GS... | Answered on Mar 15, 2019
If your iphone is not currently jailbroken, then I am afraid to say that it is not possible. If your phone is jailbroken, go to cydia, add the ihacks repo, then install yourtube 2, it is a built in youtube video downloader for your youtube app.
Apple iPhone 3GS... | Answered on Sep 19, 2018
connect ur iphone to ur pc and delete those movies
Apple iPhone 3GS... | Answered on Aug 28, 2018
As I know iTunes and iPhone/iPod/iPad can only support MP4 video with H.264 format. So you just need to use Leawo DVD Ripper to convert your DVD to MP4 format and then sync into iPod/iPad.
Apple iPhone 3GS... | Answered on Jun 13, 2018
The iphone is not too hard to repair. There is a stepby step guide too that explains a little bit at eachstep how todisassemble the iphone2.gif properly : iPhone repair. There are also third party iphone repair companies that do it for you.
Apple iPhone 3GS... | Answered on May 07, 2018
The best way to transfer music from iPod to computer is using a third-party tool like iAny Manager.
Here are what iAny Manager can do
1. Importing Music,videos to iOS devices from PC
2. Transfer files to PC from iphone/ipad/ipod
3. Getting music,playlist, apps of your iOS device back into iTunes
4. Direct Apple to Apple transfer
5. Good transfer speed without slowing down your PC
Step by step guide:
iAny Manager Transfer iOS Devices Data Backup Sync Restore Manage Data...
Apple iPhone 3GS... | Answered on Apr 28, 2018
Don't worry !! if your iphone screen has been cracked, you can get your phone replaced from your nearest mobile restore. To find your nearest mobile repair center: visit at https://smartrepair.io/
Apple iPhone 3GS... | Answered on Mar 28, 2018
this iphone repair is rated "easy"
Either you need to replace Charging dock connector ot you need new battery. but 90% chances you should change charging connector and it should fix the problem.
tech from iphone repair etobicoke
Apple iPhone 3GS... | Answered on Mar 20, 2018
Have you tried a different charger? Maybe the charger is the problem.
Apple iPhone 3GS... | Answered on Feb 25, 2018
Try putting your iPhone in recovery mode.
follow the link to see all the information you need.
Succes! How to Put iPhone into Recovery Mode
Apple iPhone 3GS... | Answered on Dec 15, 2017
If what you say is iPhone backup password, just with a computer and a tool, iPhone backup password will be reset.
iTunes Password Genius can run in Windows computer. What you need to do is run it on computer, add iTunes backup into it, and set password attack type for backup password recovery. Once all of these done, click "Recover" button is enough.
But if you want to change or disable iPhone backup password, you need to connect iPhone to computer and do that in iTunes.
If the password you say is iPhone passcode, factory reset iPhone is a method. You can reset a new password for iPhone after factory reset. However, all of things on iPhone have deleted too. Now restore iPhone from iTunes backup on computer is a best way. The backup password could be recovered with iTunes Password Genius.
Apple iPhone 3GS... | Answered on Nov 10, 2017
The battery is failing.
Apple iPhone 3GS... | Answered on May 28, 2017
If you need some iphone repair tools, you can try vipprogrammer. It is on-line exporter feayuring China Original Universal programmer, for online shop owners wholesale dropship at very low price. Vipprogrammer ship its programmer tools all over the world. Vipprogrammer promises "China Brand, Original Warranty, Competitive Price". Original universal programmers Online Shopping Store from China
Apple iPhone 3GS... | Answered on May 18, 2017
Apple iPhone 3GS Black (16 GB) Logo
690 questions posted
Popular Products
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
Travis
Travis
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
iPhone Apple
  • iPhone Apple
Most Popular Question
iphone won 39 t turn
  • Cell Phones
