20 Most Recent
Kodak PIXPRO FZ41 Compact Digital Camera - 16MP 4X Optical Zoom HD 720p Video -Black Questions & Answers
Kodak
Call Kodak at this #.... 1-800-822-1414
Regards,
Dennis
How do you remove the battery from a Kodak Pixpro AZ528?
To remove the battery from your Kodak Pixpro AZ528 camera, follow these steps:
- Turn off the camera and remove any cords or cables that are attached to it.
- Locate the battery compartment cover on the bottom of the camera. It is typically marked with a battery icon.
- Slide the battery compartment cover open. It may be held in place with a small latch or tab that you will need to release before you can open the cover.
- Carefully remove the battery from the battery compartment. It may be held in place by a small latch or spring. Be sure to grip the battery firmly to avoid dropping it.
- Close the battery compartment cover and make sure it is securely latched.
If you have any trouble removing the battery or if the battery compartment cover is stuck, you may want to consult the Kodak Pixpro AZ528 user manual for more detailed instructions.
Kodak Easyshare Z740 turns off while trying to take pictures constantly
There are a few possible reasons why your Kodak Easyshare Z740 camera might be turning off while you are trying to take pictures:
- The battery might be low or dead. Try replacing the battery with a fully charged one to see if this fixes the issue.
- There might be a problem with the camera's power supply. Try cleaning the battery contacts and charging the battery to see if this fixes the issue.
- There might be a problem with the camera's firmware. Try updating the firmware to see if this fixes the issue.
- There might be a problem with the camera's hardware. If the camera is still under warranty, you should contact Kodak for service. If the camera is not under warranty, you may need to take it to a repair shop to have it fixed.
I hope this helps! Let me know if you have any other questions.
My kodak easyshare m883 camera turns on lets me change the time and date then cuts out
please ensure that the battery isn't past it's expiration date- even if it's not been used before, an expiration m. And please ensure that the sd card does not have more data stored than was built for the camera to handle. If so, please transfer some data off of the sd card and then attempt to set the date on your camera again.
Thank you.
