Alpine Car Audio & Video • Uploaded on Oct 23, 2013
Hi jmatt313,
If you have necessary tools and test instruments, know safety precaution in
basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. -
Sometimes because of dust and any fine foreign objects build up at the top of the optical lens it can't read any disc. Try clean the lens by
soft cotton buds. Be careful while doing this.
2.Check the ribbon -
Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an
open line then of course the lens can't read the disc. Also try to erase the
contact by pencil eraser. If you've done the steps above and the symptoms still
there then the next step requires you a little knowledge in soldering technique
and reading the ohmmeter.
3.Check the motor - Check
the motor that spin the disc with an ohmmeter. You can test it using the
ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it
will spin. Bad motor-
reading will drop to low resistance and will not spin.
Hint : 50% of my repaired
unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new
one. Before replacing the new motor you have to check the clearance of the disc
holder with the old one. The clearance should be the same as the old because if
not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens
was faulty.
If you can't do the job yourself, I would advice you to look for a
professional to troubleshoot the symptom.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
39 questions posted
114 Questions
80 Questions
69 Questions
73 Questions
63 Questions
