20 Most Recent LG WT1201CV 4.5 cu. ft. Ultra Large Capacity Top Load Washer with Fron Questions & Answers
You posted your question under LG washing machines. Try reposting under air conditioner
LG Washing... | Answered on Nov 24, 2019
Not tight? Bad o-ring? Cracked housing?
sounds like it might be time to replace it .
LG Washing... | Answered on Nov 23, 2019
Pull the washer out and tilt it up against the wall. It is always better to look from underneath because the water leak travels downwards.
LG Washing... | Answered on Nov 03, 2019
You might try replacing the thermistor in the bottom of the outer tub. It's only a $6 part and pretty easy to do. Try cold only wash and see if it works. Also, try putting washer into test mode and run through each segment that it tests. Let us know results by commenting back pls
LG Washing... | Answered on Nov 01, 2019
These any good ? Direct from the LG site:
TV Dimensions with Stand (WxHxD)38.3" x 24.8" x 8.5"and TV Dimensions without Stand (WxHxD) 38.3" x 22.5" x 3.3"
Good luck.
LG Washing... | Answered on Oct 26, 2019
Spray WD 40 and wipe clean with cloth, not leaving any fibres on the PCV board.
LG Washing... | Answered on Oct 22, 2019
LE is speed sensor error. Easy replacement. Check YouTube. Are you sure it isn't 'tE" error. Thermistor error. Very common. Videos also on repairclinic.com or appliancepartspros.com.
LG Washing... | Answered on Oct 16, 2019
It sounds like the suspension dampers need to be replaced. Lubricant wears away and when the plastic meet metal it will make those odd noises as tub sways to center itself. I recommend replacing all 4 suspension dampers.
LG Washing... | Answered on Oct 10, 2019
LG WT1201CV 4.5 cu. ft. Ultra Large Capacity Top Load Washer with Fron Logo
1 questions posted
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
LG Washing Machines
  • LG Washing Machines
Most Popular Question
lg front load washer operate past load
  • Washing Machines
