20 Most Recent VIA P4X266 PE11-L Motherboard Questions & Answers
2answers
VIA RAMA U8668 (PRO) sound driver problem
You are going to have to physically look at your mainboard.
The reems of drivel you posted are all but useless, but for one line:
Motherboard Name VIARAMA U8668 (Pro)
This line ids your board as a Biostar U8668, but what you HAVE to verify is the Pro part.
Here are the downloads for a U8668:
http://www.biostar-usa.com/mbdownloads.asp?model=U8668
(it uses a C-Media audio driver)
Here are the downloads for a U8668 Pro:
http://www.biostar.com.tw/supp....php3?name=U8668%20Pro
(it uses a VIA audio driver)
If you physically LOOK at your board as seen here:
http://www.biostar-usa.com/mbs...model=U8668&socket=478
You will notice that just above (or to the left when mounted in a case) the ram slots the model number is printed on the board, what you have to verify is if "Pro" follows the U8668, and then use the appropriate driver.
3/30/2019 11:21:55 AM • VIA P4X266... • Answered on Mar 30, 2019
P4m266 pm11 driver
easiest solution just visit manufacturers website and download driver from there
5/29/2018 3:08:13 PM • VIA P4X266... • Answered on May 29, 2018
097ch driver til vin 7
Hello here is the driver site:http://www.viaembedded.com/en/products/boards/others/p4x266_pe11_l.jsp#driversHere is no drivers for windows 7.The mainboard is too old, for that windows system.Buy a new pc, or continue useing windows xp.Good luck
2/14/2013 1:17:29 PM • VIA P4X266... • Answered on Feb 14, 2013
2answers
Internet connection
You need to install the LAN driver for your motherboard from your motherboard CD.
11/9/2012 4:00:25 PM • VIA P4X266... • Answered on Nov 09, 2012
2answers
Please sent my driver for
11/9/2012 3:51:43 PM • VIA P4X266... • Answered on Nov 09, 2012
U8668 pro sound drivers problem
You can download your driver here in the audio driver section http://www.via.com.tw/en/products/mainboards/others/p4x266_pe11_l.jsp just click the download button
8/2/2011 5:24:05 AM • VIA P4X266... • Answered on Aug 02, 2011
I dont have sound ,
http://www.via.com.tw/download/mainboards/2/2/audiodrv.zip
7/6/2011 10:05:31 PM • VIA P4X266... • Answered on Jul 06, 2011
Get sound card motherboard mbp4x266
So watx the problem?
8/9/2010 1:41:45 PM • VIA P4X266... • Answered on Aug 09, 2010
Soun card via p4x266 8233
Heres the link for your drivers:
Hope this will help
7/22/2010 7:29:19 AM • VIA P4X266... • Answered on Jul 22, 2010
Which processors are compatible with VIA
The number is a big giveaway P4=Pentium 4
http://www.via.com.tw/en/products/chipsets/p4-series/p4x266a/
5/9/2010 11:28:21 AM • VIA P4X266... • Answered on May 09, 2010
asus web site tpye in board numbers it will show you jim
4/14/2010 12:40:53 PM • VIA P4X266... • Answered on Apr 14, 2010
4answers
I CAN'T INSTALL A WINDOWS XP SOFTWARE
Thank you for choosing Fixya.com
Yes you can install the Windows XP on P4X266.
Here could be five various steps you can go about.
  • Method 1: Perform a clean install of Windows XP
    Use this method for a clean installation of Windows XP. A clean installation removes all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk.
  • Method 2: Upgrade to Windows XP
    Use this method if you are upgrading to Windows XP from Microsoft Windows 98, Microsoft Windows Millennium Edition, or Microsoft Windows 2000 Professional.
  • Method 3: Install Windows XP to a new hard disk
    Use this method to install Windows XP to a new hard disk. This is typically done when a new hard disk is installed on your computer.
  • Method 4: Install Windows XP to a new folder (parallel installation)
    Use this method to install Windows XP to a new folder (parallel installation) to either run two operating systems, or to access, repair, or retrieve data from a damaged disk.
  • Method 5: Perform a multiple boot operation
    Use this method to install Windows XP as a separate operating system on your computer. This lets you install more than one operating system on your computer and select which operating system that you want to use every time that you start your computer.
To check the detailed information, check this Microsoft Knowledge Base Article.
http://support.microsoft.com/kb/316941
Hope this would help !!
Regard's
Anurag Shukla
9/8/2009 11:12:32 AM • VIA P4X266... • Answered on Sep 08, 2009
2answers
Via ac 97
unfortunatley we cant get that drivers but try using this website... www.drivermax.com ... in that isntall the software and this will take care of ur drivers...u can get ur drivers from this site...
8/5/2009 12:43:36 AM • VIA P4X266... • Answered on Aug 05, 2009
7answers
Via ac 97
GINKO, your the best!!!
i give you many thanks...... your tip and link posted in this page realy helped me solve my freaking problem...
again thanks a lot!!!
pls. send me your contact email so i could have you emailed my pc problems... thanks
[email protected]
3/29/2009 1:00:45 AM • VIA P4X266... • Answered on Mar 29, 2009
Sir, i want via p4m266a-8237 driver cd
Hi Sir,
You can download your VIA drivers from following link.
http://www.viaarena.com/default.aspx?PageID=2
Don't forget to rate me sir.
Thanks
2/28/2009 6:50:10 AM • VIA P4X266... • Answered on Feb 28, 2009
My bios ID = P4X266-PE11-T
check with your motherboard manufacturer's website download page and check whether your motherboard supports flash update.
2/19/2009 6:26:47 PM • VIA P4X266... • Answered on Feb 19, 2009
VGA not workin proper
This product seems to be no longer suppported via the web site:
http://www.via.com.tw/en/products/mainboards/download_main.jsp
1/24/2009 5:07:50 PM • VIA P4X266... • Answered on Jan 24, 2009
When pc boot it will display " bios checksum error "
check whether there is an os cd inside the drive and remove it. else reinstall the os
12/29/2008 2:31:38 PM • VIA P4X266... • Answered on Dec 29, 2008
Need sound driver for p4m266a-8237
12/29/2008 7:09:03 AM • VIA P4X266... • Answered on Dec 29, 2008
VIA P4X266 PE11-L Motherboard Logo
46 questions posted
Top VIA Computers & Internet Experts
MegaByteMe
MegaByteMe
Aron
Steve Pack
Steve Pack
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • VIA Computers & Internet
Most Popular Question
u8668 pro sound drivers problem
  • Computers & Internet
