20 Most Recent Aiwa NSX-D77 CD Shelf System Questions & Answers
The manual is available for free at retrevo.com. On page 12 it explains it.
It's basically an interplay between a tuned station and the keys that stand for Pause or Stop.
Aiwa NSX-D77 CD... | Answered on Apr 11, 2010
Hi JACQUELYN MOORE, so you say you have problems in the function control system, you might have some of the keys locked and that does not answer any other
Check all the keys and see if any are locked
and comment
Hola JACQUELYN MOORE, por lo que comentas tienes problemas en el sistema de control de funciones, puede ser que tengas alguna de las llaves trabadas y eso hace que no te responda ninguna otra
Revisa todas las llaves y ver si alguna esta trabada
y comenta
https://www.manualslib.com/products/Aiwa-Cx-Zr525-372985.html
Aiwa Audio... | Answered on Sep 24, 2019
I have been having a problem with my above-mentioned turntable. What is happening is that when I load a record onto the platter and press "start" ... questions:if you put the arm on the record without start button,what happens? ... I have a pxe850 in my garage, i think it's a newer equivalent of the pxe800,
Aiwa Audio... | Answered on Aug 22, 2019
It probably is stuck due to failure of the mechanism.
Aiwa Audio... | Answered on Jul 10, 2019
Hello Emmett, for what you know, it is very possible that the contact that drives the engine has been stuck or stuck, that's why it's still working, you'd have to remove the bottom cover of the tray, with the power cable unplugged and find the key in question and unlock it
If you have technical knowledge, he sent you the service manual,
but go to a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Emmett, por lo que cuentas, es muy posible que se haya quedado pegado o trabado el contacto que acciona el motor, por eso sigue funcionando, tendr?as que retirar la tapa de abajo de la bandeja, con el cable de corriente desenchufado y encontrar la llave en cuesti?n y destrabarla
Si tienes conocimientos t?cnicos, te envi? el manual de servicio,
sino dir?gete a un servicio t?cnico especializado
espero puedas resolver el problema
Saludos Franco Dosil
https://www.manualslib.com/manual/869440/Aiwa-Px-E860.html
Aiwa Audio... | Answered on Apr 26, 2019
Google is your friend. Use it. Check yelp for a shop u find.
Aiwa Audio... | Answered on Feb 24, 2019
Aiwa would be a possible source.
Aiwa Audio... | Answered on Feb 11, 2019
It could be as simple as a broken belt that drives the tray that holds the CD. You will have to look inside and see. Sometimes the door can get stuck if it's been knocked out of place too!
Aiwa Audio... | Answered on Jan 11, 2019
Aiwa NSX-D77 CD Shelf System Logo
2 questions posted
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Aiwa Audio Players & Recorders
Most Popular Question
clear pre set tuner stations cx na909
  • Audio Players & Recorders
