20 Most Recent
Powerline Netgear XE102 Ethernet Bridge Network Adapter - XE102 (XE102NAR) Questions & Answers
The middle light on my netgear ethernet bridge xe102 wont stay on
-- Xe102 device is simply a plug n play device
-- so if the connection light shut off after some time
-- first hard resett the powerline adapter
-- and after that get the powerline checked
-- If that doesnt work there is no specific configuration
get the adapter replaced ..
4/7/2010 5:15:57 PM •
Powerline...
Answered
on Apr 07, 2010
I have a logitech cctc
You might have a 64-bit Windows installed. The drivers on the CD are only for 32-bit windows. Download and install the latest drivers from Logitech website (http://www.wilife.com/Support/Downloads.aspx), which includes the 32-bit and 64-bit versions. Hope this helps !
3/27/2010 9:40:00 AM •
Powerline...
Answered
on Mar 27, 2010
Widows cant find thr driver
Hi, Please note that this powerline adapter does not require any drivers to work. It is a plug and play device and will work without a software. The software can be used just to encrypt the network
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
7/27/2009 11:32:41 AM •
Powerline...
Answered
on Jul 27, 2009
Myy rocketfish powerline ethernet switch kit RF-HTN 105 and 106
These type of things can not be plugged into power boards they have to be plugged into the wall socket, you can then plug a power board into that if you want, The other thing is they both have to be on the same circuit or same breaker switch then you just plug a network cable from the modem to the powerline switch & the other one plug a network cable from the switch to your computer & bingo it's done
6/22/2018 2:04:48 AM •
Powerline...
Answered
on Jun 22, 2018
