20 Most Recent
Aiwa AV-X120 Questions & Answers
The lighted display has started to darken - cannot
This problem is not depending on a kind of LED or bulb. The reason is that the display is a VFD (Vacuum Fluorescent Display) with no additional illumination.
The most common problem with VFD is, that the heater of the VFD is going bad. You can't change it because it is built-in. For experienced repairman it is possible to higher the heater voltage or the anode supply to gain the brightness a bit. But thats a tricky thing.
Sometimes it may help to clean the display cover from inside. This is what you can do first. The reason for getting dark by dust inside the cover is that the VFD is working with a anode voltage wich is a bit higher (about 30V - 50V). This sucks the very fine dust electrostatically into the casing.
To clean up the protective display cover from inside, remove the casing and also the cover in front of the VFD and clean the dsplay protection cover (the VFD istself is usually clean). Maybe that's it - but maybe not (that means the VFD is going bad).
Hope it helps.
12/9/2013 10:26:08 PM •
Aiwa AV-X120
Answered
on Dec 09, 2013
LED display has gone dark
Check if the display you this coming cathode voltage, which is 5VAC, chances are that there is this voltage, follows the line of this voltage, possibly find some open fuse. luck.
10/13/2013 1:30:40 AM •
Aiwa AV-X120
Answered
on Oct 13, 2013
I have an AIWA AV-X120
In this receiver the display is a digitron type: the badges, letters and numbers are created by a fluorescent paint applied on a set of electrodes encased in a vacuumed glass box - basically an improved version of a nixie tube.
Because of they way it's build the display ages over time, like a tube of a tv - the fluorescent paint wears out. Because of that it can't be repaired or regenerated. And since the production of displays of this kind has stopped long ago there are no replacements.
You will have to try to find a defective unit with a good display and have it swapped - search for it in used goods shops and sites. If you can't locate one use your unit as is for as long as you can then buy a new one.
8/7/2011 9:30:48 PM •
Aiwa AV-X120
Answered
on Aug 07, 2011
Information display lighting very dim. I need the
There are few websites offer schematics/ service manuals for products and your required schematics are available
HERE for small fee. Because schamtics/ service manual is technical document of a product so it wont be available for free over internet as user/ owner manuals are almost free.
Hope these info will help you.
Thanks.
1/28/2011 8:16:54 PM •
Aiwa AV-X120
Answered
on Jan 28, 2011
Aiwa Z-L700 cassette player will not work but CD player is fine. Is there a simple solution please?
The complexity of the solution depends on the problem. The drive belt or pinch roller may be worn or have a hardened surface. If the tape doesn't turn at all or only very slowly in any function, verify that the tape drive motor is running and that the belt is turning the pulley(s). If the tape tends to tangle up, check the pinch roller. Sometimes cleaning the roller with a cotton swab dampened with rubbing alcohol will work, but if it's too hardened, you'll need to use rubber conditioner or replace it.
If nothing at all happens when you select the tape function, there may be an electrical problem such as a dirty contact on the function switch or a broken wire in the tape mechanism.
This is far from a comprehensive repair guide; it only covers the most common issues other than broken plastic parts. "Will not work" is too general to provide more than that. Cleaning the pinch roller and its drive pin can be done through an open cassette door; everything else most likely requires taking stuff apart, observing operation and perhaps making voltage measurements.
Need manual for a Aiwa cx_na777
Certainly! Here is a basic manual for the Aiwa CX-NA777:
- Powering On and Off To turn the CX-NA777 on, press the Power button located on the top right of the system. To turn it off, press the same button again.
- Changing the Volume Use the Volume control knob located on the front of the system to adjust the volume. Turn it clockwise to increase the volume and counterclockwise to decrease it.
- Selecting a Source To select a source, such as the CD player or the radio, use the Function button located on the front of the system. Press it repeatedly until you reach the desired source.
- Using the CD Player To use the CD player, press the CD button located on the front of the system. Insert a CD into the tray and press the Play button to start playing the CD.
- Using the Radio To use the radio, select the Radio source using the Function button. Then use the Tuning knob to tune into the desired station. You can also use the Preset buttons to quickly access your favorite stations.
- Using the Tape Deck To use the tape deck, select the Tape source using the Function button. Then insert a cassette tape into the deck and press the Play button to start playing it.
- Adjusting the Sound To adjust the sound, use the Bass, Treble, and Balance controls located on the front of the system. These controls allow you to adjust the bass and treble levels, as well as the balance between the left and right speakers.
- Using the Clock and Timer The CX-NA777 features a built-in clock and timer. To set the clock, press the Clock button and then use the Tuning knob to set the correct time. To set the timer, press the Timer button and then use the Tuning knob to set the desired start and end times.
- Using the Remote Control The CX-NA777 comes with a remote control that allows you to control the system from a distance. The remote control features buttons for all of the main functions, including Power, Volume, Function, and CD playback.
- Troubleshooting If you experience any issues with the CX-NA777, such as a CD that won't play or a radio that won't tune properly, consult the user manual for troubleshooting tips. You can also contact Aiwa customer support for further assistance.
Note: This is a basic manual and may not cover all features of the Aiwa CX-NA777. For more detailed instructions, please consult the user manual that came with your system.
How to turn on mic on aiwa NSX 580?, please.....thank you
To turn on the microphone on an Aiwa NSX-580, you will need to follow these steps:
- Press the "Menu" button on the remote control.
- Use the "up" or "down" arrow buttons to navigate to the "Mic" option in the menu.
- Press the "Enter" button to select the "Mic" option.
- Use the "up" or "down" arrow buttons to navigate to the "On" option.
- Press the "Enter" button to turn on the microphone.
Note that you may need to connect the microphone to the audio system first before turning on the microphone. Also, refer to the user manual for more information.
