20 Most Recent
Aiwa VX-T1470 14 in. TV/VCR Combo Questions & Answers
Need to reset pin on
how do i change brightness/colour/contrast if i dont have the romote control for the aiwa VX-FT 21. video/TV combo. My screen has got really dark and I cannot find a manual pannel to change it form on the TV - me and all my friends have looked everywhere but there - if someone could email me at
[email protected] that would be great. Thank you
How can i fix color broplem of the television?
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
Has dvr/tv/combo loss remote tring
It mainly depends on the universal remote you are trying to use. What is the make and model of the universal remote? Did it provide any Aiwa codes? Usually what i do is just start going through every code in the book til you find one that works. Time consuming but it works.
Thanks,
Lee
Tv is showing prtected and switchging it self off
I own a Grundig TV and if it becomes locked then I have to phone the company and pay £50 to get it unlocked.
When I received my TV there was a leaflet inside which gave me a number to phone.
Also, contact the company as they may be able to help you if you cannot find a number.
Code
PIN CODE RESET - UNPLUG SET FOR 2HOURS, VOL TO MIN. PRESS VOL- ON SET & "7" ON R/C FOR 5 SECS WHEN "PROTECTED"
Tv Channels
well reprogram your tv. i beleive there is an access infront of the tv. if not with your remote control.
Aiwa VX-FT21
select P+endP-thogheder end power up of swche stby 5,6 sec end relaes after this select stby of remont control
Aiwa CXZM2600 no sound. Speaker module OK.
There are several common faults that can cause a lack of sound on the Aiwa CXZM2600 front panel circuit board:
- Damaged components (e.g. capacitors, resistors)
- Loose connections
- Badly soldered joints
- Blown fuses
- Failed audio amplifier IC It's recommended to check these potential issues and to have an experienced technician diagnose and repair the fault.
I Have An Old Aiwa Stack MX-Z9300m and i don't have the remote
It sounds like you're looking for a replacement remote control for your Aiwa Stack MX-Z9300m. Unfortunately, since your stack is an old model, it might be difficult to find a new remote control for it.
Here are a few options you can consider:
- Check with Aiwa directly. Contact Aiwa's customer service and inquire about the availability of a replacement remote control. They may still have some stock of the original remote, or they may be able to provide you with information on where you can purchase one.
- Check with electronics repair shops. Some repair shops may have the original remote control, or they may be able to repair or replace the remote control you have.
- Check online marketplaces. Check online marketplaces such as eBay or Amazon for used or refurbished remote controls for your Aiwa Stack MX-Z9300m. Keep in mind that buying a used remote control may not be guaranteed to work properly, so be sure to research the seller's ratings and reviews before making a purchase.
- Invest in a Universal Remote Control. You can purchase a universal remote control that can be programmed to work with your Aiwa Stack MX-Z9300m. These types of remotes are widely available and can be found at many electronic stores or online.
- Consult the user manual or the technical specifications of your Aiwa Stack MX-Z9300m. You might be able to find information about the remote control that was originally used with the stack. With this information, you may be able to find an appropriate replacement remote control.
It's important to keep in mind that some of these options may not be an exact match for your Aiwa Stack MX-Z9300m, and may not have all the functions of the original remote control.
It's also important to check the Aiwa Stack MX-Z9300m's warranty status and the manufacturer's instructions to ensure that the repair or replacement will not void the warranty.
