20 Most Recent
Aiwa XD-DV370 DVD Player Questions & Answers
The dvd player is frozen,
I have one that is the same way, but looks like the circuits never reset, all lights stay on. plus will not open
Hi i have aiwa dvd
salamalaykum brother,
i am located in afghanistan at the moment, maybe i can help you if you explain the problem.
regards
MY DVD PLAYER AIWA MODEL XD-DV370EZ THE POWER
MOST LIKELY POWER SUPPLY ISSUE ON THE BOARD. I WOULD VENTURE TO GUESS IT IS ONE OR MORE CAPACTIORS, RESISTORS, AND OR DIODES. PLEASE BE VERY CAREFULL WHEN DEALING WITH CAPACTIORS. ONE INCORRECT TOUCH AND YOU WILL END UP IN THE EMERGENCY ROOM.
This DVD player has worked
the motor that drives the laser has packed up and to repair it will cost more than going down to your local chinese shop and buying a new one for around 35 euros ,when you buy a new one get one with usb and sd card play facilities ,these cost around 10 euros more but you do not need dvds ,just download a film ,copy to memory stick and play.
Dvd player
You have to change the Video System. If you select it rightly, i.e. PAL or NTSC, there will be no problem.
Aiwa CXZM2600 no sound. Speaker module OK.
There are several common faults that can cause a lack of sound on the Aiwa CXZM2600 front panel circuit board:
- Damaged components (e.g. capacitors, resistors)
- Loose connections
- Badly soldered joints
- Blown fuses
- Failed audio amplifier IC It's recommended to check these potential issues and to have an experienced technician diagnose and repair the fault.
I Have An Old Aiwa Stack MX-Z9300m and i don't have the remote
It sounds like you're looking for a replacement remote control for your Aiwa Stack MX-Z9300m. Unfortunately, since your stack is an old model, it might be difficult to find a new remote control for it.
Here are a few options you can consider:
- Check with Aiwa directly. Contact Aiwa's customer service and inquire about the availability of a replacement remote control. They may still have some stock of the original remote, or they may be able to provide you with information on where you can purchase one.
- Check with electronics repair shops. Some repair shops may have the original remote control, or they may be able to repair or replace the remote control you have.
- Check online marketplaces. Check online marketplaces such as eBay or Amazon for used or refurbished remote controls for your Aiwa Stack MX-Z9300m. Keep in mind that buying a used remote control may not be guaranteed to work properly, so be sure to research the seller's ratings and reviews before making a purchase.
- Invest in a Universal Remote Control. You can purchase a universal remote control that can be programmed to work with your Aiwa Stack MX-Z9300m. These types of remotes are widely available and can be found at many electronic stores or online.
- Consult the user manual or the technical specifications of your Aiwa Stack MX-Z9300m. You might be able to find information about the remote control that was originally used with the stack. With this information, you may be able to find an appropriate replacement remote control.
It's important to keep in mind that some of these options may not be an exact match for your Aiwa Stack MX-Z9300m, and may not have all the functions of the original remote control.
It's also important to check the Aiwa Stack MX-Z9300m's warranty status and the manufacturer's instructions to ensure that the repair or replacement will not void the warranty.
