I Googled my washer to look up some stuff i couldn't find for my own washer other than here and i did not see E08 as an error code in my manual or on any of the other websites but i did see F08 followed by E01 which was a water supply error:: and you have to check for proper water supply:: check the hoses and the faucets to be sure that the screens are not clogged and the hoses are not kinked to clear the code touch the power button once then touch the power button again to restart the washer if the code appears again the manual says to call for service to send out a service tech.
I found this reference on the web ... from a repair technician on a Maytag Maxima>>>
So I'm really sorry to bring you this bad news, but let me explain your error codes. F06 E02 is a communication error between your MCU (motor control unit) and your CCU (central control unit). You'll want to remove the top panel, the control panel, and then the front panel of the washer and make sure the wire connections to the motor control unit below the tub are all secure. If everything checks good, you'd need to have the MCU replaced.
From a different reference on a similar Maytag MHW6000XW2 ... also indicating communication issue
Usually ... hidden somewhere on the inside of the washer you will find the service technician paperwork which has all sorts of additional detail.
Helpful?
Good luck on your troubleshooting!
Leveling: Ensure the washer is properly leveled. An unbalanced load can trigger the UL (unbalanced load) code. Use a level to check if the machine is sitting evenly on the floor.
Load Distribution: Make sure the clothes are evenly distributed in the drum. An imbalanced load can cause the UL code to appear.
Calibration: Some models have a calibration mode that can be accessed through the control panel. Running a calibration cycle might help the washer to detect load balance more accurately.
Electronics: There could be an issue with the control board or wiring harness. Inspect these components for any visible damage or loose connections.
Professional Service: If none of the above steps resolve the issue, it may be time to consult with a professional appliance repair technician who can diagnose and fix the problem more accurately. They may have specialized tools and knowledge to pinpoint the exact cause of the UL code.
Ld is long drain, so either the pump is blocked, the pump impeller is worn or the drain hose is blocked.
I had a drain blockage on a Miele and it was cause by an apple stalk lodging itself across the ridges of the drain hose and had collected enough lint to block it, This was a machine that was washing towels commercially for 16 hours a day.
Unhook the drain and watch it pumping either into a bucket or into a laundry sink. It should fly out in a jet!
If yours is a top loader it will mounted near the drum inside the machine. It will be a shaped block of concrete curved to sit close the actual drum. The most like places will be at the front, nearest you when your putting clothes in it, at about 3/4 of the way off the floor. It could also be in a similar place at the back of the machine.
Unfortunately, if you can't get to it, you need a new machine. Normally you would seal with silicone or epoxy putty. The only thing I can can think of is injecting polyurethane expanding foam into the area, but go easy it expands for 10 minutes and you would have to shield any moving parts.
Most parts are obsolete.
es, in order to remove the top of a Maytag LSE1000 washing machine, you'll need to first disconnect any attached wires. This is because the wires are connecting important components like the control panel and the sensors to the rest of the machine.
Here are the steps you can follow to safely disconnect the wires:
Unplug the washing machine: Before you begin, make sure to unplug the machine from the power source to prevent any electrical shock.
Locate the wires: Look for the wires that are connecting the top of the machine to the rest of the machine. They should be near the back of the machine where the top and bottom halves of the machine meet.
Label the wires: Label the wires so you know which wire goes where when you're ready to put the machine back together. You can use masking tape and a marker to label each wire.
Disconnect the wires: Gently pull the wires from their connectors, making sure to keep them separated so they don't get tangled. Be careful not to pull too hard, as this could damage the wires or the connectors.
Repeat the process for all the wires: Repeat the process for each wire until they're all disconnected.
Once you've disconnected all the wires, you should be able to remove the top of the machine. Make sure to keep the wires organized and in a safe place while you're working on the machine. When you're ready to reassemble the machine, simply reconnect the wires in the reverse order you disconnected them.
notify a repair company for quotes or online search for part ----fixya is an online repair forum we dont send repair personal out or sell manufacture or ship products
Unplug your washing machine for a few minutes which will let the electrical charge to dissipate from your washing machine that will let it reset then. If it is still not working unplug it for 10 minutes.Or you will have to access the real switch then which is under the lid housing by pushing the washing machines drum to the back.
Yes, they don't make them like they used to and it is definitely worth fixing. Black dust is almost certainly the belt. Pull the machine out and tip it backwards against the wall. Have someone hold it steady and look underneath with a flashlight.
Worn bearings make a noise.
Parts 30 on drawing 1 is your belt. $39 Canadian. It is a long belt! Make sure the pulleys are okay and the motor and gearbox turn freely.
