20 Most Recent Sony PlayStation 2 (PS2) Console Questions & Answers
Ps2 powers up, but disc is not spinning and
Following could be the reasons for not spinning any PS2 disc:
  • A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
WATCH this video to clean lens
  • An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
  • A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable.
No Spin At All If your spindle hub is NOT SPINNING AT ALL, NOT EVEN 1/2 OF A TURN, it may be bad or unplugged. A tell tale sign of it being unplugged is if you hit eject, the laser moves down the rail, and starts grinding because the PS2 keeps trying to move it down the rail even though it hit the end. There's a small switch on the spindle hub that tells the unit to stop pushing the laser because it's reached the end. Spindle hubs usually do not go bad by themselves, usually either the PS2 too a bad fall and it became bent [try spinning it by hand], or someone the cable out and put it in too many times [or incorrectly] and the silver contacts on the cable were detached.
12/16/2023 7:45:53 AM • Sony PlayStation... • Answered on Dec 16, 2023
3answers
THE VIBRATION OF MY PS2
If your ps2 controllers aren't vibrating anymore then this could be the fix that you were waiting for.
WARNING: Make sure that 1) Its not your controller that is broken, test it in a machine that does have vibration. 2) Make sure that the vibration option is turned ON in your games
If you are sure that your controllers aren't broken, then you may have blown a fuse inside your ps2 on your mainboard.
To fix it you have to remove a blown fuse from the ps2 mainboard and either put a new fuse there or replace it with a piece of single strand wire. The point is fairly small so you need a fine tip soldering iron and a single strand of wire. It may be best to get someone who is good at soldering to do this fix for you:
I take no responsibility for anyone breaking their ps2 when performing this fix. All I know is that i've done it and it worked a treat!
You will need;
1) A fine tip soldering iron and some thin solder.
2) A single strand piece of wire, something thin like kynar or enameled wire.
3) A game with vibration function to test the ps2 afterwards.
4) A controller that works with vibration.
Between the power supply connector and the PS9 fuse there is a small black square with 2 silver prongs on the left hand side. This featured on my mainboard as well, and I was able to locate the correct / broken fuse using a multimeter. Look for a fuse with S7 on the top near here, and check for continuity, If there is none then thats the one! One last thing before it goes into full detail;
Check the track between the black square with the silver prongs and the broken fuse, if its on the same track then you can attatch one end of the wire to that prong that is on the same track, and the other side to the end of the fuse opposite of the black square with silver prongs *
This will take bout 10 mins to do - start to finish.
Below tells you how to do it
Below is a description on where and what to look for i.e. the fuse, and how to repair it.
1. I have a V5 PS2
2. Take the PS2 apart.
3. Remove the Power Supply motherboard.
4. After removing the Power Supply Board, you will need to remove the metal shroud and expose the entire PS2 Motherboard.
5. Once you have done this look around the connector for the Power supply board on the PS2 mother board. You will see a number (maybe around 4 of them all located within 2 inches of the Power supply connector) of fuses with "S7" written on it.
6. The one you are looking for has the text "PS9" written on the motherboard next to it.
7. Check it with a multi-meter, for continuity, there will none. If you are not sure, you can check all of them, when the buzzing on multi-meter stops, that's the one.
8. To repair it, use a strand of wire, possibly from an old extension cable or something, but only one strand. Solder it on both sides of the fuse in order to close the connection.
9. Reassemble the PS2.
10. Boot up and play your game, vibration is back.
Hope This Helps
11/18/2023 7:14:46 PM • Sony PlayStation... • Answered on Nov 18, 2023
2answers
No power on my ps2
Ok this is a classic bad power supply! There could be 2 solutions to this! 1 a new power supply or a new 50 cent fuse!
If you are willing to tear it apart ... but that is if this is a fat ps2.. If it is let me know and we can get cracking!
6/10/2022 9:25:48 PM • Sony PlayStation... • Answered on Jun 10, 2022
PS2 Green LED remains on, system won't turn on
have you tried holding down the reset button to turn off your console. Months before I bought my Ps2 I noticed my friends turning off their PS2's using the switch on the back. When i bought mine , months later i was invited to a friends house and noticed when he turned off his ps2 by holding the reset button down for a few seconds. After playing on their trampoline i went home and tried this reset button thing and it worked. Although i had the fat bulky ps2 this trick also works on slimline models too. This should solve your problem. The switch on the back i later found out was for when you wanted to turn off your ps2 during a thunderstorm.
12/8/2021 3:38:20 PM • Sony PlayStation... • Answered on Dec 08, 2021
2answers
My playstation 2 is lagging
Try dusting out the ps3, and if that doesn't work clean the lense.
10/21/2021 12:40:38 PM • Sony PlayStation... • Answered on Oct 21, 2021
How to change region code on ps2 scph-90002
How do you change region on ps2 SCPH-39001
10/19/2021 3:57:44 AM • Sony PlayStation... • Answered on Oct 19, 2021
2answers
I have ps2 model no.SCPH-90004 CB.... can i
Yes if your PS2 is hacked you can connect an external hard drive.
10/5/2021 12:28:24 PM • Sony PlayStation... • Answered on Oct 05, 2021
2answers
When i try to my turn my ps2 slim on.The button turns red
try this:
1. turn off PS2
2. unplug PS2
3. plug PS2 back in
4. turn on PS2
hope this helps.
it's from the manual :D
8/25/2021 12:30:38 PM • Sony PlayStation... • Answered on Aug 25, 2021
Entering Madden 10 cheat codes on ps2.
you may have to unlock it
8/7/2021 6:09:33 AM • Sony PlayStation... • Answered on Aug 07, 2021
2answers
Play station 2 disc read error
sony jst ripped us off with ps2. u know, always making something not perfect so they could sell a better product, does ps3 sound familiar. im sure something will be similar to ps3, then ps4 comes out, so on and so forth. mostly, i cant play rockstar games in my ps2, the video and audio doesnt match, then it jst freezes on loading scenes. jeeze.
6/12/2021 3:26:57 AM • Sony PlayStation... • Answered on Jun 12, 2021
3answers
Playstation 2 region unlock
Hello there.
To region unlock your Playstation 2 console you need an unlock DVD. Something like http://www.play.com/Games/PlayStation2/4-/94716/-/Product.html
Hope this helps.
4/6/2021 5:07:35 PM • Sony PlayStation... • Answered on Apr 06, 2021
Cheats on naruto accel 2
Unlockable Characters Beat certain events in Master (Story) Mode.
Unlockable How to Unlock Chiyo Meet her Master (Story) Mode Chiyo with Puppets Beat Sasori True Form in Master (Story) Mode with her Deidara Beat Deidara in Master (Story) Mode Itachi Beat Itachi in Master (Story) Mode Kabuto Beat Kabuto in Master (Story) Mode Kisame Beat Kisame in Master (Story) Mode Orochimaru Beat Orochimaru in Master (Story) Mode Sai Beat Sai in Master (Story) Mode Sasori Hiruko Beat Sasori in Master (Story) Mode Sasori True Form Beat Sasori True Form in Master (Story) Mode Sasuke Beat Sasuke in Master (Story) Mode Yamato Beat Sai in Master (Story) Mode
12/19/2020 11:48:29 AM • Sony PlayStation... • Answered on Dec 19, 2020
4answers
My game freezes at the same spot every time
First step should be to change the game by the new one (or clean the disc). If this still not help please advice.
5/25/2020 6:44:04 PM • Sony PlayStation... • Answered on May 25, 2020
2answers
PS2 wont play DVD movies!
Hi. It seems that you might have an old version of the PS2.
The original PS2's had a problem with the laser that read CDs and DVDs, often failing, creating problems with reading DVDs and in rare cases, CDs.
Unfortunately, the class action lawsuit filed against Sony is too old to get yours fixed for free, but there are ways to attempt to fix the laser yourself, if you would rather not send it in to Sony.
http://www.eurasia.nu/wiki/index.php?pagename=Ps2LaserAdjustmentAndReplacementGuide
If you have any other questions, respond and I'll help you the best I can.
Good Luck!
2/26/2020 8:05:13 AM • Sony PlayStation... • Answered on Feb 26, 2020
I put game in and i get no destination available
Can we play games through pendrive after downloading the game in pendrive?
2/23/2020 1:31:21 AM • Sony PlayStation... • Answered on Feb 23, 2020
2answers
Ps2 will play ps2 dvd games but wont play dvd movies
might want to check the parnet settings on the system
1/2/2020 6:06:46 AM • Sony PlayStation... • Answered on Jan 02, 2020
2answers
PS2 Fifa 08 unplayable after playing online
one thing you should do is try to put either alcohol or perfume on tisse paper and wipe the dvd. it should work. another thing it might be the laser that is damaged. but try the perfume or alcohol it works.
12/18/2019 3:52:56 AM • Sony PlayStation... • Answered on Dec 18, 2019
2answers
Fix a halfway stuck tray on a ps2
There must be a broken piece of the tray thats blocking the process. Try to open the console using a screwdriver and get rid of the broken bits
12/15/2019 8:13:29 AM • Sony PlayStation... • Answered on Dec 15, 2019
Sony PlayStation 2 (PS2) Console Logo
Popular Tags
5,351 questions posted
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
PlayStation Sony
  • PlayStation Sony
Most Popular Question
cheats naruto accel 2
  • Video Game Consoles & Games
