20 Most Recent ViewSonic N2000 20 in. LCD HDTV Questions & Answers
Blipping power
Ur tv power on the picture just show up only for a few sec. U still have sound?Yes,than ur LCD inverter board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
5/16/2010 6:00:04 AM • ViewSonic N2000... • Answered on May 16, 2010
TV lost power suddenly, won't turn on. No orange
Check the fuse.
3/23/2010 4:06:40 PM • ViewSonic N2000... • Answered on Mar 23, 2010
3answers
Fuzzy Display
try to reset the device into factory defaults, you should be able to perform that from the menu. then set the native resolution and perform the auto adjustment.
5/3/2008 2:47:12 PM • ViewSonic N2000... • Answered on May 03, 2008
Fuzzy Display
check your sharpness control in the adjustment setup. If its set to max you might or sme sets have a tendancy to look grainy. Also check your source and be sure the signals strong. Such as just adding another tV to a cable line can cause weak signal. Ceck it with another set in its place. If thats the case simply add a small 20.00 cable amplifyer. Good Luck
4/27/2008 6:59:17 PM • ViewSonic N2000... • Answered on Apr 27, 2008
5answers
Why is my vizio tv's picture black and white?
it could be your flux capacitor is out. you might need to plug it in goto menus and check to see if ur runnin 21 gigawatts if not leave it plugged in and off for two days and it should refresh it
12/29/2022 9:16:23 AM • ViewSonic... • Answered on Dec 29, 2022
3answers
Does anyone have a manual for a Viewsonic Remote RC00315P?
Full instructions and codes here. For what it's worth, no one buys universal remotes these days, you buy a facsimile remote which is an exact copy for the television model you have. www.remotes.com. https://universalremote.codes/viewsonic-tv/ ..
10/27/2022 7:17:30 PM • ViewSonic... • Answered on Oct 27, 2022
2answers
How can I unlock osd on my TV viewsonic n2011
OSD Lock: Press and hold [AUTO] and the up arrow for 10 seconds. If any other buttons are pressed the message OSD Locked will display for 3 seconds. OSD Unlock: Press and hold [AUTO] and the up arrow again for 10 seconds. http://www.viewsonicglobal.com/public/products_download/user_guide/Display/VA1903A/VA1903a_UG_ENG.pdf?pass
3/2/2022 5:27:24 PM • ViewSonic... • Answered on Mar 02, 2022
I have a 2008 ViewSonic N4785p. It will turn itself off and on with no patterns or reason. Any suggestions?
check power settings see if program set
9/19/2020 4:55:18 AM • ViewSonic... • Answered on Sep 19, 2020
Remote will not turn on but will turn off ViewSonic
The 'ON' button is not working. Pls go for a new remote.
5/21/2019 8:01:05 AM • ViewSonic... • Answered on May 21, 2019
Tune dtv on viewsonic n3246w-e tv without remote
Have a viewsonic n3246w but can't get it to tune in on dtv
4/25/2019 7:29:36 PM • ViewSonic... • Answered on Apr 25, 2019
Tune my viewsonic n3246w tv
First make sure that the current input Source is set to TV to see the option for scanning for channels. There is a Source button on the front of the TV. (It's on the right side as you look at the front of the TV.) The Source button on the original remote is on the left side below the number keys.There are two RF (coaxial) cable inputs near the VGA port on the back of the TV. The digital RF signal needs to go to the port above the VGA port. To scan for analog channels, press the Menu button. Then navigate to the TV setup option with the Up/Down arrows. Press OK to enter the menu. You can use either the Auto search or the Manual search. However, the Auto will be faster. You can set your country or leave it to Auto. Navigate to Start and press OK for the Auto-scan. There is a DTV menu button above the Volume + button on the remote. Use this menu and look for the Installation section to scan for channels. Again there is an Auto or Manual option. ManualsLib has the manual for the Viewsonic N3246W here: https://www.manualslib.com/manual/306714/Viewsonic-N3246w.html. See page 23 for the start of the analog TV channel scan information. See page 30 for the digital TV scan. I hope this helps. Cindy Wells (For any channel provided by a set-top box, you will not be able to use the TV to store the channel lists.)
4/25/2019 6:17:35 PM • ViewSonic... • Answered on Apr 25, 2019
I have a Viewsonic TV N2201W LCD TV Model # VS12247-1M Serial # R2**********, when I turn it off a box comes up Power Lock and my TV won't shut off. Does anyone has such problem. Please help
Some Viewsonic monitors have a Power Lock feature. However, these tend to be on the monitors (like the Viewsonic VA2265Smh) with only 5 control buttons. To toggle off the power lock, press and hold the button labeled 1 (Menu/Save/Exit) and the down arrow button for 10 seconds. The N2201W TV has more buttons than that. There is no Power Lock identified in my Viewsonic TV manuals. However, you might try the press and hold Menu/Down arrow combination. I hope this helps. Cindy Wells
2/18/2019 12:57:22 AM • ViewSonic... • Answered on Feb 18, 2019
I have a ViewSonic tv model N2011 when I press menu button osd locked is what I have in my screen, channel up or down same thing only the volume button don't make it can I know how to get ride of this message in my screen TV please
To toggle the OSD lock off, press the Vol + and Vol - buttons on the Viewsonic N2011 simultaneously. This is shown in the manual on page 8, see https://www.manualslib.com/manual/306712/Viewsonic-N2011.html?page=8#manual . I believe these buttons are on the back of the unit on the right hand side as you face the TV. I hope this helps. Cindy Wells
1/15/2019 11:20:35 PM • ViewSonic... • Answered on Jan 15, 2019
My viewsonic tv its stuck on no media device how do i fix it without a remote
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done./
5/30/2018 12:34:39 PM • ViewSonic... • Answered on May 30, 2018
N3235w remote control not working
EXACT remotes are often VERY expensive... I would recommend a NEWER "Universal Remote" that will not only empower your TV, but enable you to use FEWER remotes! Here is a EIGHT FUNCTION REMOTE Starting at $7 from Target! GE Universal Remote Control 8 Device Fully Backlit DVR Functions Black Anthony
5/20/2018 8:23:54 PM • ViewSonic... • Answered on May 20, 2018
ViewSonic N2000 20 in. LCD HDTV Logo
5 questions posted
Top ViewSonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • ViewSonic Televison & Video
Most Popular Question
blipping power
  • Televison & Video
