20 Most Recent
Samsung Galaxy Tab 3 Tablet 10.1" TFT 1280 x 800 Android 4.2 Jelly Bean 16 GB microSD slot Wi-Fi Bluetooth - White - GT-P5210ZWYXAR Questions & Answers
Hi i have a samsung tablet gt-p5210 &it keeps shutting down sometimes i go to play a different game &it just shuts off help!!! Thanks
specify weather it is plugged in or not when this happens and if the battery is above 30%
if plugged in, is the plug getting loose if so replace the wire that charges it and plug will be tight again . clean around plug with folded paper corner to be sure nothing is inside pressed to back of plug slowly shorting power. batteries do wear out in these things so only plug back into charge when it is below 20% and let it charge all the way up. as each partial charge cost you one of the 1000 charges in the battery's life. get Battery Doctor from the play store it will trickle charge at end of cycle and will tell you the battery's health. good app.
Tablet won't charge
Your charging port (where you jack in the USB to the samsung tab) but first try another Samsung USB plug and flex
Tablet instructions
You can find the instructions for how to setup your secure wireless connection in the Huawei manual. And in the little booklet that came with your Samsung you can read how to connect to Huawei.
don't forget to make a note about the name and password you gave in on the Huawei.
please don' ask me to type over these pages, because one way or the other, you have to read it. Better take the booklets.
Tablet problems with touch of the screen
let's start with the basics first in order to solve your tablet issue. Once we go that, we can move forward as necessary.
I would recommend performing an antivirus scan on your device. You can search for "avast" or "malwarbytes" in your app store to get started.
If that doesn't work, then you can perform a factory reset as described by Samsung here:
https://www.samsung.com/us/support/answer/ANS00062842/ . You'll be advised to back up your files before performing the factory reset.
Please let me know if this helped you or not.
