20 Most Recent
Baby Jogger City Twinner Stroller Questions & Answers
How do I fold my
There are 4 pins that need to be pulled. 1st Flip the stroller over and remove the 2 back wheels...sqeeze the metal piece by the wheel and pull the wheel straight out. Pull the 1st 2 pins, they are between the back wheels and the front wheel, on either side. The bars these were holding in place will swing up. Then pull the 2 front pins (by the front wheel) and flip the front tire up. The front wheel also comes off but isn't neccesary.
Collapsing the stroller
If your wheel is in the locked position it won't collapse all the way. Make sure the wheel is in the swivel position and that it is facing out. Hope this helps!
Littlema
Twinner II
You need the tube# and I would think that Canadian Tire should have them, even Wal-Mart. 16" is a popular size and could probablyget it at any store that sells bikes.
Baby jogger broken footrest
Re: Baby Jogger Broken Footrest
I just had this problem on my Baby Jogger City Versa. I had to get creative as both buttons were missing. On each side there will be two open slots. You can use a flat screwdriver on the side without a button and insert the screwdriver into a slot and push til you feel it go in, while pushing the button on the other side. You will probably need someone to adjust the footrest while you hold both sides in. It's a pain but it will allow you to get it in the position you want. I'm looking into whether I can get replacement buttons but haven't found anything yet :( Hope this helps!
