20 Most Recent
DIANE von FURSTENBERG Ernestina Dress - Black - Size 4 Questions & Answers
What is braided cable used for?
It helps to know on what?
All questions need 'make model (what it is)'.
Then you have over 40,000 categories to choose from. You posted to the category 'Clothing'. I don't know any clothing that has braided cables, braided 'edges' yes. So lets go out on a limb and say this is the wrong category as well.
Braided cable in coaxial antenna cable is used to aid flexibility and also provide and earthing connection and also protection from electromagnetic interference to the inner signal core.
In phone charge cables it is used to protect the inner cables from flexing damage but also give superior strength and flexibility. A perfect example is the cheap and nasty, but expensive Apple cables in white plastic sheathing, they are timed to fail in about 2 to 3 years.
If that is not the information you wanted click Comment under this box. I know everything so can answer you, I will get a notification that you would like further help.
3/16/2024 3:02:17 PM •
Clothing
Answered
on Mar 16, 2024
Variety Products
Saree, Leghens, Gown, Bridal Collections, western wear, dress materials etc.
http://shethalboutique.free.nf/
I want to take my stuff off of ebay I have listed cuz they r sold
To end a listing early and cancel all bids or sell to the high bidder:
- Go to My eBay > Selling and find the item.
- From the More actions drop-down menu, select End My Listing Early.
- If there are bids on your item, choose how you want to end your listing.
- If there are 12 or more hours before the end of the listing, select Cancel bids and end listing early or Sell item to high bidder.
- If there are fewer than 12 hours before the end of the listing, your only option is Sell item to high bidder.
Note: If your item has no bids, you can skip this step
- Select the reason you're ending your listing early and click End My Listing.
11/11/2023 7:29:21 AM •
Clothing
Answered
on Nov 11, 2023
I have an issue with an adjustable dress form that I would appreciate some help with
Hello Isabell
4 hours, or 4 years? The only thing you can do is ask your nieces where they got it and go and exchange it. They should do that without a receipt. If it is 4 years, then it is doubtful they will exchange it. Sell it on Facebook Marketplace or a dressmaking forum and get another preferably, an adjustable dress form.
You are sure you won't put the weight back on, or is it your wish to keep the weight off?
Best of luck and keep well.
Andrew
9/17/2022 5:32:03 PM •
Clothing
Answered
on Sep 17, 2022
I am trying to find "inspirations by maidenform"
Hi. you can search for maidenform workout pant on the internet and it will come up many different sites where you cant buy it from, but make sure to search up the website it it is safe first :)
3/5/2022 3:10:29 PM •
Clothing
Answered
on Mar 05, 2022
Unscaled setting
Your question doesn't make sense. It's not even a question.
7/30/2021 12:56:22 AM •
Clothing
Answered
on Jul 30, 2021
Ck7749s
which part
7/27/2021 1:44:19 AM •
Clothing
Answered
on Jul 27, 2021
To take greasy spots on laundered shirt?
Several techniques may be attempted. Most say give it a second go if the first attempt does not fully do the job. Bur ALWAYS read the laundering instructions for the particular fabric. None of these are for silk or delicate fabrics.
1 The Baking soda method
Combine table spoon of glycerin and dishsoap in 1.5 cups warm water in spray bottle. Spray. Let soak 20 min.. Wash in cold water with table spoon of baking soda added. Hang to dry.
2 Just the dish soap method
Soap it, rub the fabric together, let is set an hour, wash it out with cold water.
3 Laundry detergent method
Same as 2 but use laundry detergent.
4 Other alternatives to dab the stain with on a paper towel, then wash out. (One per trial, not a mixture. Wash out before next.)
- Shampoo
- Aloe vera gel
- Hairspray
- Cornflour or baby powder
- WD-40
- Rubbing alcohol
6/19/2021 2:28:10 PM •
Clothing
Answered
on Jun 19, 2021
How to fix reset canon printer problem?
If you are unable to reset the Canon printer then try some of the tips, just keep following for the same. Firstly, make sure there is no pending print job. Uninstall the Canon printer software from the control panel. Delete the printer from the "Printers and Faxes" If you can't reset the Canon printer from your system manually then use the "Reimage Plus Software" it will replace the corrupt and missing files. Most of the time it works, if it isn't then, contact our certified Canon technicians on our toll-free number for the complete solution to your Canon printer orhttp://www.number-customerservice.com/canon-printer-support/ ,
A down jacket is a warm jacket
A down jacket is a warm jacket that is filled with the soft feathers of a duck or goose, and the outer layer is usually made of materials like nylon or polyester. Down, the soft feathers mentioned, are usually taken from the ******* and wings of the duck or goose. Down is the material which provides the insulation that makes down jackets so warm, as they retain heat inside the jacket. Generally, the more fluffy the down is inside the jacket, the more air gets trapped inside the jacket, and the higher the ability of the jacket to keep out the cold. However, today, most down jackets are not made of pure down, and are often mixed with other materials, such as feathers.
