20 Most Recent
Panasonic Workio DP-3520 Copier Questions & Answers
Print gets black too much
Are you getting alot of background? If so then the developer is overtoned & needs to be replaced. If you are getting black lines then that is caused by the main charge being dirty, upper fuser roller needing to be replaced due to wear or the drum is "lined" out or the drum blade is warped.
Panasonic dp 3520 driver
Drivers and compatibility information is available at the below link.
http://panasonic.net/pcc/support/mfp/
Panasonic DP 3520 J62 only when using stapler
The stapler mechanism may be jammed. try to make sure it works freely. It has to "crimp" the staples similar to a car crushing machine. They usually give the customers a little tool to unjam the staple unit. Good luck.
Machine
An E4-02 occurs after 7 consecutive jams at the fuser. Possible causes are:
Paper exit sensor# 1 or 2 disconnected or defective.
DRV pcb is disconnected or pcb is defective.
SPC pcb is disconnected of pcb is defective.
Hope this helps
I NEED TO EMPTY THE
Open the right transport cover, then remove three screws from the right rear cover. That's the one with the opening for the network port. The waste bottle slides out and can be emptied.
How do I connect our
Hi! just add new device with device manager new network printer or scanner and give the right ip address and install drivers if needed.
And what do we do
The code can be reset in service mode, LBP fuser reset.
E04-02 indicates a jamming problem in the fuser unit, usually accordion jams. Correct the fuser problem prior to resetting the code.
