20 Most Recent
Mach Speed Eclipse 180G2 Series 4GB* Video MP3 Player Questions & Answers
Eclipse Mach Speed Trio T2810C Charger?
To charge the player, simply connect it to a powered USB port, or external AC adapter. If you choose to use a third party adapter, please ensure that it is 5V and between 350 and 1000 mA , or 1amp
amazon has Excelity AC-DC 5V 1A Wall Charger Power Adapter with Plug 5.5 x 2.5mm / 5.5 x 2.1mm $9.00
Personally i would use computer charging for USB ports.
Google play store
The google play store is already incorporated in the Android device. If you mean that you aren't able to download apps off the store, it most likely is because you have not logged in to your Google account which you might need to make if you don't have one. Once that is set up, everything should work just fine.
How to download music
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer. You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
I'm new to this. Where do I find the software
This is just a suggestion you might try I have a T2800 player so may be different but the following is what I had to do. Hope it helps you When you connect the player to your computer, it will act as a removable disk drive. Inside, there is a folder called "Tools & Manual". Open this folder, and then the "Tools" folder.
My screen on my trio t2810C is frozen. how do i un freeze the screen
Look at the very top of the device. There is a little silver button. Take a pin or some sharp small object and depress this button. Once the screen goes black, let up on the button and boot (turn on) the unit. Other than a few lost settings it should be functioning normally. If not...you get what you pay for.... =)
How to download music on it
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files b>
Volume will not change on my trio v2 plus
In the playing music mode, press the center button one time and then hit either the button to the right to raise the volume or the button to the left to lower the volume.If you hold down the center button it gives you other options.
