20 Most Recent
Panasonic Workio DP-1820E Copier Questions & Answers
Panasonic dp-1820e paper not detected
Listen to see if the lift motor is working properly...if it doesn't lift the paper then the machine will think there is no paper installed in the paper tray. The lift motor will need to be replaced if this is the issue.
I have aficio MP-5000 what
SC-220 =
The laser synchronizing detection signal for the start position of the LDB is not output for
two seconds after LDB unit turns on while the polygon motor is rotating normally.
Which could mean:
• The Copy Data Security Unit card not installed
• The Copy Data Security Unit card is installed, but it is not the correct type for the machine.
Or a problem with the laser unit itself.
A reboot normally clears the error.
Hope this helps.
How to set paper size panasonic workio 1820
Press "Function" key scroll to general settings , Press "set", scroll to "09 Key operator mode" Press set, Enter 3 Zeroes as the password. Scroll to "01 Paper size" press arrow keys (left/right) to desired size ,press set and then Stop to exit
Load paper error message when using legal paper.
you have to program the paper size anytime you change the size of paper you use in a lot of panasonic machines. This is done through the
function" feature... go intofunction... general settings...scroll down to key operator mode...the code will be "00000000" (8- 0's) and it will be in one of the first screens up
