20 Most Recent Panasonic Panafax UF-585 Plain Paper Laser Fax Questions & Answers
Remove Error code 021
Press Function 7 monitor slowly 4 times * 6 scroll down to SHIPMENT SET set 2 wait for the fax to initialize and come back to READY
5/28/2015 4:06:36 PM • Panasonic... • Answered on May 28, 2015
0answers
0answers
0answers
Language set
Be the first to answer 6/26/2013 2:14:35 PM • Panasonic... • Posted on Jun 26, 2013Be the first to answer
Rcv to memory password
No 2 manufacturers use the same method. However it is unlikely that you need a password. To print the contents of the SAF memory, it requires a simple procedure. Either there is a resume button, or sometimes use the copy button or the start/copy button. Let me know which machine it is.
6/7/2013 6:50:12 PM • Panasonic... • Answered on Jun 07, 2013
2answers
Panasonic Copier Error Code
Hello I have a panasonic kx-FT983CX, it can't copy but when copied is not clear.... Please tell me.Thank you very much!
2/26/2013 10:03:27 AM • Panasonic... • Answered on Feb 26, 2013
0answers
PAPER JAM MESSAGE, BUT CAN'T FIND ANY JAMMED PAPER
look at the paper tray,some of your sensor are jammed,try tyo find out where is the sensor on paper try
12/15/2011 8:51:03 AM • Panasonic... • Answered on Dec 15, 2011
Panasonic Panafax UF-585/595 prints 5"
It sounds like the fuser unit is on its way out. The cost to fix may out way the price of a new one. You should bring it in to a certified Panasonic repair centre to get a quote though. Fuser units are worth about $300. It could also be a failed toner. Try taking the toner cartridge out and gently nock it back and forth to free any stuck toner.
Chris
8/19/2011 2:41:21 AM • Panasonic... • Answered on Aug 19, 2011
0answers
I have a Panafax UF-585 and the display went out.
They are nice machines, pretty bulletproof. Repair of this machine is worth it. Panafax tech for 15 years
3/5/2011 12:20:51 AM • Panasonic... • Answered on Mar 05, 2011
The lcd screen does not work any more and i cannot
hi hahudson,
I think you need a physical service of that fax machine.
mastergani
2/4/2011 7:57:59 AM • Panasonic... • Answered on Feb 04, 2011
Can you add a new fax no that shows in the header
To set Outgoing Fax Number/ ID follow the follwing steps: -
- Press FUNCTION, Press 7 (Set mode will appear on display)
- Press 1 (User Parameters Settings)
- Press Set repeatedly until display shows ID
- Enter your Number/ ID (max. 20 digits) by using the key pad
For further information you may refer to User Manual for Panasonic Panafax UF-585 Page 29
Hope it helps! Good Luck!
CreativeTECH
2/3/2011 9:58:02 AM • Panasonic... • Answered on Feb 03, 2011
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
126 questions posted
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Office Equipment & Supplies
Most Popular Question
panasonic copier error code
  • Office Equipment & Supplies
