20 Most Recent
Panasonic Panafax UF-885 Plain Paper Laser Fax Questions & Answers
Unreadable
Sounds like a driver problem. Remove that printer, go to the manufacturer's web site & download current drivers. If your printer is connected via USB, turn off or disconnect the printer before installing the new drivers, then connect to printer when prompted. Another thought, verify that the correct printer is chosen from within the app you are printing from.
12/16/2013 7:09:12 AM •
Panasonic...
Answered
on Dec 16, 2013
Error code 061 and the ADF door is closed
In this case make sure that the plastic tab that actuates the sensor is not broken off. If it is, try and find some way to defeat it. Other wise you will have to replace the whole transmit door assembly.
8/1/2013 11:21:42 AM •
Panasonic...
Answered
on Aug 01, 2013
Replacing the LCD battery on a Panafax UF-885
Open up the document feeder by pulling straight up.
You will see a white tab sticking out of the black base.
Push FIRMLY towards the rear with your thumb.
The battery is a CR-2032 as printed on it.
11/3/2012 4:23:07 AM •
Panasonic...
Answered
on Nov 03, 2012
Battery low panasonic fax machine
1. Turn the power switch to "O" (OFF) position.2. Open the ADF door.3. Remove the battery together with the battery holder.CAUTION: Dispose the Lithium Battery properly and keep it away from children.Replace the Lithium Battery(Order No: CR2032)CAUTION: When replacing the battery, make sure to observe the polarity to avoid damage to the machine.4. Install the Battery Holder into the machine.5. Close the ADF Door.6. Turn the power switch to the "I" (ON) position.NOTE: The service life of the battery is approximately 1 year when the machine is turned "off"
3/9/2012 1:31:25 AM •
Panasonic...
Answered
on Mar 09, 2012
I would like to forward
Try entering *72########### where #=fax # that you want to forward to. To end forwarding, enter *73. This depends on if your carrier supports call forwarding.
6/10/2011 5:43:14 PM •
Panasonic...
Answered
on Jun 10, 2011
How to replace fuser? Panasonic, Panafax uf-885
The lower tray and the left cover must be removed, inside you will find the fuser (last place the paper passes through before it exits the left side.
Remove the screws and unplug the wires, reverse order to replace.
1/3/2011 9:29:20 PM •
Panasonic...
Answered
on Jan 03, 2011
Shows 91% memory
press
Function
7
monitor slowly 4 times
* star key
6
scroll down to all job clear
set
machine will now reinitialize
2/26/2010 9:19:32 PM •
Panasonic...
Answered
on Feb 26, 2010
