These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
This is its power supply regulator problem itself. If any resistor [used in the start section circuit] has developed high value, or has a loose solder terminal, this could happen. If you wish to get some details, check the site linked here.Pull up older posts.
After lamp replacement, certain adjustments should be done. To get more details, check this site.
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and press 'Enter'
or view it in Mosaic / Timeslide option.
Average life on a OEM or original lamp is 2000 hours---about 2 years depending on how much you use the set---only real way to know if lamp is the problem (other than looking to see it is not shattered inside) is to replace it---either it is or is not the problem.
hi, check the brightness setting on ur tv. if u have already checked it, then check ur tvs lamp. its time to replase the lamp. may be its reflector get damaged. thats why the brightness is low. ok
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
This is lamp of your tv (lamp with housing) that you will see inside tv. Click Toshiba Support to download user manual copy and check page-50 to 52 for lamp replacement instructions. Thanks.
Hi Thanks for using FixYa. To reset the TV you’ll need
to disconnect the TV from the power socket and mains, remove all the cables
from/to the TV and let it without power for about 10 minutes and after it plug
all the cables back and switch it on. To replace the lamp use a Philips screwdriver
to open the small square shaped lamp compartment panel on the side or back of the
TV and pull the lamp out slowly to remove it. Now clean the lamp holder and new
lamp with a micro fiber cloth. Please make sure to turn off and unplug the TV
for at least 1 hour to drain off current from all components
especially capacitors before you perform any repairs. Also note that the TV
consists of very high voltages even when it is in off position. Before
performing any repairs I’ll suggest you to try and reset the TV by unplugging
it for 8-10 hours. Please do accept the solution if the issue is resolved or
post a comment for further assistance. Thanks Rylee
