20 Most Recent
Samsung Galaxy S4 Mini Questions & Answers
Charging paused battery temperature too low
The Samsung cells have four contacts. Two are for the voltage (sometimes marked as + and -) and two are for the temperature sensor. If the sensor is not communicating, the phone will detect an error and report it as low temperature. Try using a new cell and see if the message returns. If not then the old cell has a bad sensor. But if it returns, check that the four golden spring contacts in the phone are good, not bent, and the same length. If one of the contacts is bent, have it fixed.
Does photo storage drain battery quicker?
Dear Avril,
Photos storage will not affect Battery.
- Most likely you have a few or a lot of Apps running in the background depending on the application(s).
- Check & remove Unnecessary Apps. The usual culprits are Social network Apps & Excessive Notifications.
I have included a link to manufacturer's website
Good Luck
JP
Global Download Center
How do I call Asia on my phone
There are locked and unlocked versions of this phone. If you have an 'i' in your model number then you have to call your provider to fix this problem. Singapore area/country code is (+65).
If you don't have the 'i' in your model number then I'm afraid you might have a greater issue, again your phone provider will be able to help you.
