20 Most Recent
SWANN ADS-440 SwannEye Indoor/Outdoor Security Camera Questions & Answers
My Swann 960 h pro series security camera system is flashing green light
A flashing green light on a Swann 960H Pro Series security camera system can indicate a few different things, depending on the specific model and configuration of your system. Some possible causes of a flashing green light include:
- The camera is in setup mode: When a camera is first powered on, it may flash a green light to indicate that it is in setup mode and ready to be configured.
- The camera is in standby mode: When the camera is not actively recording, it may flash a green light to indicate that it is in standby mode and ready to start recording.
- The camera is recording: Some models of the Swann 960H Pro Series security camera system have a green light that flashes when the camera is recording.
- The camera is low on power: Some models of the Swann 960H Pro Series security camera system have a green light that flashes when the camera is low on power.
- The camera is malfunctioning : Some models of the Swann 960H Pro Series security camera system have a green light that flashes when the camera is malfunctioning.
I have to Swann security cameras will they work my Bunker Hill DVR
1st lets figure out how old your swann cameras are?? If they are within say 5rs old and are digital. Then the answer is YES they should work no problem. After all a digital signal is a digital signal. Unless encrypted of course. Given you have the correct connectors that go from the camera to DVR you should be fine. If not, you can find adapters at any decent electronics store. Kinda like Radio Shack used to be. That is unless you are wireless, then the above "connector" comment is jibberish, and should be ignored.
Good luck Mr. Morgan
Jason
