20 Most Recent
Toshiba 35A44 35" TV Questions & Answers
Sound but no picture toshiba 35a44
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience.
Pull up older posts.
Toshiba 35A44 turns on then right off again
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Do a search by type in the brand name of your device at its search box.
Manual
I'm sure you have googled it? There is a website that links to zillions of manuals. Type in TV manuals. It might be web crawler. Sorry can't remember name but should some up if googled.
Anthony
Screen suddenly has only a thin bright middle
If it has a white line in the middle running left to right the problem is in the vertical circuit.This can come with age as solder connections (this is the most common cause) come loose or break at the chip in that circuit.Much of the time with set on a good hard rap on the top or side and the line will try to open and return a full picture.Someone who can get to it and can solder can fix that---the chip will usually have 7-13 pins and be mounted on a metal plate that is fairly small(it keeps the part cool)---fixed a lot in less than ten minutes.You will have to open the set, locate the chip(usually a location number on top of board by it will be something like IC301 or 401).Most of the chips will have a generic number on them a LA------ or such. You will have to remove the board to look at the bottom where the chip solders in.I attach a photo of a typical chip.Let me know if questions
Whats the worth
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Rcr312wr isnt turning on my toshiba 36af61
You should synchronise the remote control with Toshiba codes. Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in webSetup codes and synchronisation method can be had from this site. Pull up older posts there.
Missing power button
there is one thing you can do cheaply,
open the tv by pass the switch, put straps a cross switch contacts.
only two polarities enters your tv live and netrual, each one goes a cross the switch.
program your remote
0156,0060,0154.
or 060,019,014,052,054,075.
