20 Most Recent
Blu Studio 5.0 Mobile Phone Questions & Answers
My phone was working place it on charger went back and the phone is dead will not come on
The same thing happened to me. It's probably your charger porter. did you somewhat yank the charger out sometime or did it fall of a table or something and the charger yanked itself out when it fell (if it fell). If that's the problem, try putting the charger in the phone & hold the charger up, worked for me. You could also try a different charger or buy a battery charger like I did. There's the link if of the battery charger if needed. I hope this helps!
http://onepluswireless.com/products/universal-external-cell-phone-battery-charger-charges-most-brand-phone-batteries
BLU Studio 5.0 II will not download text message pics.
This is due to your APN settings. I'm not sure which carrier you use, but the problem is generally associated with MVNO companies of the major carriers. This means: Net10, Metro PCS, etc. The Studio 5.0 II does work with all GSM carriers, so this is a plus. It's just a matter of identifiying which one you have, and putting in the right info. You can download the app 'Tweaker' from the Play Store, and it will tell you everything you need. Good luck.
I accidentally deleted my Google keyboard
Hi Yvonne
With the smartphone turned on, press and hold the "Power" button
Tap and hold "Power off"
In the Safe Mode prompt, tap "OK". Your smartphone will reboot in safe mode
After the device reboots, the "Safe Mode" label should be present on the screen
To uninstall an app, tap the "Applications" icon while on the home screen
Tap "Settings"
Under "Device", tap "Apps"
Swipe to the "Downloaded" screen
Select the desired application and tap "Uninstall"
Tap "OK" to confirm
To exit safe mode, press and hold the "Power" button > tap "Power off"
Once the smartphone is turned off, press and hold the "Power" button to reboot your device as you normally would
Receiving message android. Process.acore has stopped. How can I fix this
Do you have your contacts backed up?
Try uninstalling Facebook if that is installed. If this does not fix your problem then try the following.
Settings>Applications>System Applications>Contacts Sync Adapter and press Clear Data, this error usually goes away. If this doesn't work, try clearing the data on Settings>Applications>System Applications>Contacts or Settings>Applications>System Applications>Contacts Storage.
If problem is fixed, then restore contacts and reinstall Facebook and make sure you don't sync contacts with it.
Good luck. Im going to sleep.
Sorry if this wasn't helpful
Phone not connecting to internet
Ive had this problem. Its going to burn thru your data if you dont connect to the wifi. Tryl to turn the phone off then back on again. Sometimes this works.
Phone is stuck in no command. I
Hi if u see the android guy with his internal circuits and an exclamation mark no stress. You are in recovery mode press the power key once you will see options reboot now will be highlighted press vol up and your phone will start up normally.
Or you can pull the battery and put it in back and turn on ur phone :) hopes this helps
I creatred a anti theft password on my BLU STUDIO 5.0 ANDROID phone but i cant remember it
Osee, Never put passwords or pin codes on the net. Never give these away. You are a good victim for phishing.
I did delete the password, because no one can help you with a password issue. This security was put there so no one can open the phone and steal your data.
The only thing you can try is use caps on and of.
When you really can't find the password, the only thing you can do is a complete rest of the phone. You will lose all data on the phone if you succeed but you again can use it.
Make a not the next time you use a pass word. And really keep this secure with you.
