20 Most Recent
Mach Speed Trio Stealth G2 8 inch Tablet with 8GB Memory Questions & Answers
How to reset a trio stealth g2
If you can power it on go into settings then backup and reset. This will reset tablet to the out of the box status. You will loose all of your data. If it will not power up, press power and volume up while booting till the screen comes on.Boot options will come up then reset. Be sure the tablet is fully charged.
FREZZES ON THE 9 DUAL CORE
Hi:
Try my generic fix for tablets. Press the on/off button and at the same time, press Volume+ button. Seems to have worked for many people. If it doesn't you may have a virus or you may have to try and reset it back to when you first got it. Hope my generic "freeze" fix, works.
LindaSView
Get my trio stealth to turn on?
By far the most common fault with Android tablets and in many cases there is no fix which is disgraceful...
Its called a Boot loop caused by too many apps memory consumption, os or bootblock corruption - press the reset button (its a small pin hole usually on the back of the tablet) with a pin
If that doesnt work switch on and press the power and up volume buttons
You will be in recovery mode
Select recover system then reboot
You can also load a new os from an sdcard -cyanogenmod - google it.
If that doesnt work then i am afraid you are in deep - you will have to attach to your pc with usb cable , download and run the android dev kit and use the command line to sideload or repair the tablet. You will probably find you can still browse you files but the OS is hosed - Difficult if not impossible to fix without a factory reflash/reload.
What downloads for my computer are there to communicate with my trio stealth 8
"Communicate" is a vague term. When you connect a tablet to a computer it is usually recognized as a folder containing files (data). You can move files between the two devices. You can also connect via Bluetooth if your laptop and tablet BOTH have Bluetooth.
It is better to ask a question stating what it is you want to do rather than ask about concepts.
Trio Stealth G2
This is the most common problem with tablets - there are literally hundreds of people asking the same question and i have had the same problem myself - its usually corrupt bootloader or OS and can be a nightmare to repair.
Sounds like its borked.Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.if none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up. Its actually a disgrace and I have been repairing computers and latterly tablets for the last 30 years and it is by far the most common issue with any tablet except Apple - there is a reason they are so expensive - lol
