20 Most Recent Microsoft Surface 2 with 32GB Questions & Answers
Since the release of the latest Surface revs, problems are continuing to be reported where the Surface will boot into a screen that requests the BitLocker Recovery Key before it can continue. This issue was also reported with the first revision of Surface devices, however, it was not as widely reported as it is now.
This result can be caused by a wide range of things such as corrupted drivers or Windows Updates not able to install successfully. Whatever the reason, you'd like to be able to get past the BitLocker Recovery Key request screen, but have no idea how to locate this extremely long number.
Luckily, Microsoft stores this number for you in the Cloud. Using a working computer connected to the Internet, just jump out to the following link and ensure you are logged in with your Microsoft account.
https://skydrive.live.com/recoverykey
When you access this link, you'll something similar to below, except yours will contain the actual Key ID and abnormally long Recovery Key number.
Microsoft... | Answered on Oct 01, 2019
Yes it should drivers, that's what make everything work. When you do an update Microsoft will at some stage include Driver updates as well, that is why Updates are so important as they keep your Tablet computer, working as it was designed with the improvements to the system over time. Now I started with a Surface 2, and then over time I upgraded to a Surface Pro 3, then a Pro 4, which I have at the present time. I made sure mine had 16 gigs of memory and 256 gigs of storage which I find is all I need as I use an external drive of 1 Terabyte for storage. I also found over time that if the charge is dropping while in use I just put it back on to charge to keep the battery well charged at all times. By doing all these regular housekeeping duties with the Surface, they have never let me down. I like my Surface Pro 4, you probably would to, but now they have Surface Pro 6's on the market and they are just the best of Tablets that you can buy, even though a tat on the dear side, but that's what you get when you buy Quality. Best of luck.
Microsoft... | Answered on Jan 12, 2019
what you are trying to put it on might not have enough space available for it
Microsoft... | Answered on Apr 12, 2015
The BitLocker Recovery Key is intended to add an additional level of security, ensuring that only the authorized owner of the Surface can unlock the device and restore access. Unfortunately, if you can't find your key, or your key does not display on the Microsoft account page, you'll need to restore the Surface to factory default settings, i.e., start over.
Microsoft... | Answered on Mar 30, 2015
Go to the search button and type Internet Explorer ,, it will show you the file.. then go to the folder and right click and copy and paste the file name to the desktop in a shortcut to have it available.
Microsoft... | Answered on Mar 16, 2015
If you have a Surface RT you can only go through the Windows Store and search for "Netflix", then install it. You can also always just to go www.netflix.com from your device and log in to enjoy your Netflix.
If you don't have the RT version, you can just download the Netflix application from www.netflix.com and run it to install.
Happy Netflixing!
Microsoft... | Answered on Feb 25, 2015
What is your question? Did you forget your password to open your Surface? If so, please follow the directions in this link.
Microsoft Surface Tablets
Microsoft... | Answered on Feb 15, 2015
Check for dirt in charge port; if dirty try a clean dry toothbrush to clean the contacts.
If still buggy, consider taking to store and see if it charges with sample power supply.
Microsoft... | Answered on Mar 04, 2014
This is on Microsoft. Until more third-parties start developing apps for the device, this will not be fixed.
Microsoft... | Answered on Dec 16, 2013
Have to go with headphones here, the speakers are a known issue that has not yet been solved. It's a hardware problem that won't be fixed on your tablet.
This is a known issue with Touch Cover, go with Type Cover. It costs ten bucks more but is well worth it.
Ask Microsoft if you can return and replace.
You should have had in the box with your Surface 3 Tablet a charger. It will have a plug with 2 points that is for your power plug, and at the other end you will have a natty little flat magnetised plug for the side of your Tablet. Mine is at the bottom right slot, looking at the screen of your Tablet. Now when the power is turned on, a small bright light will glow. That is now informing you that the battery in your Surface is being charged. Now at the bottom right of your Task bar, that is the Bar on the bottom of your screen where you can place program short cut Icons for your convenience. Now the speaker Icon which is there toward the right-hand side and has a cross if off, or a different look when on. Now the next icon on its right is the one that tells you how much charge is in the battery, if you touch it, it will come on to the screen informing you how much charge you have in the battery. If I'm using my Surface a lot and I do I keep it on charge while I work as a precaution to keeping my Surface well topped up. Hope this helps.
Microsoft... | Answered on Mar 12, 2019
Microsoft Surface 2 with 32GB Logo
24 questions posted
Top Microsoft Tablets & eReaders Experts
Ekse
Ruben Caraballo
Ruben Caraballo
 Mikey
Mikey
Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Tablets & eReaders
Most Popular Question
surface shows battery not charging icon
  • Tablets & eReaders
