20 Most Recent
Trio Stealth G2 7 inch Tablet with 8GB Memory Questions & Answers
How do I download apps onto this device?
The default on most tablets is to install apps to internal storage so the SD card does no good by itself. You can go into Settings>Applications and change the location for each app to the SD card. Likewise anything else you put on a tablet, particularly photos and videos get stored in internal storage. If you have taken a lot of photos and videos they can fill up your storage quickly. You can change this in the Camera app by tapping the settings icon and changing the storage option to SD card. You will still need to actually move existing photos and videos to the SD card manually or copy them to external storage and delete them. I would also change the image and video resolution in Camera settings to 640x480. This is plenty good enough for pictures you just want to look at on the device or share online.
Wall charger replacemnt
Go to amazon.com and search "Trio Stealth G2 charger"
or, if you can't wait
check the OUTPUT voltage and amperage on the old charger (for example, it could say: "5.0 VDC --- 1000 mA" (that means 5 volts, 1000 milliAmp), and find a standard charger with same voltage, and same or higher amperage.
Will not switch on
I got it. For father's day. It has given me problems. Since I got it. Can we fix it? Alvin Hardy.
When i turn it on it says trio stealth g2 and stays there and won't turn the rest of the way on.
Perhaps the HARD RESET PROCESS can help you, Merrill. I've posted my suggestion as to how it's done HERE. (
http://www.fixya.com/support/t25341481-trio_stealth_new_when_power_goes ) , so you may findt that information useful.
I've had good success with HARD RESETTING when trying to correct errors like forgotten password, or forgotten lock-patterns. However, I've had a Trio Stealth G2 that displayed the SAME problem as yours, Merrill, and it would NOT respond to ANY attempts at resetting. I tried every combination I could : pressing volume down (-) and power; volume UP (+) and power; volume UP & DOWN (+ AND -) and power. It refused to boot. But since the case and the screens were in great shape, I went on Ebay and bought a Trio with a cracked screen, swapped the motherboard from THAT tablet and it worked perfectly.
Final caution, though: ask the Ebay seller to guareantee the physical condition of the ports and other controls on the unit before you buy it. Remember you need a working motherboard.
Best of luck to you, Merrill!
My trio wont work!
try your charger with some other device
if its working then there is a problem with your charging ic
or processor
go to othorize service centre
Triomp3 com
Did you "LONGPRESS" the power button? If the tablet has powered down completely, you will need to PRESS and HOLD the power button for it to restart.
Once it's up and running, a single press and release on the SAME power button will invoke the "Sleep" mode or the "Awake" mode, depending on its last state.
Its a crack inside my screen and i didnt know how to fix it so i opened my tablet to see what was wrong and i didnt see anythning. so i put it back together and its not turning on!!!!!!! please hel
(1) Is the battery charged? I'd connect the charger for at least 10 to 15 seconds anyway, while doing the following step.
(2)Are you holding the Power button long enough when you try to restart the tablet? It will need to be held down for a few seconds (perhaps 5 or 6) while you wait for the TRIO start-up screen to appear. Once it gets there leave the tablet to boot up fully.
If that does happen without further glitches should be able to go back to using the tablet as before.
(Was it working even with a cracked screen? Were you able to get the cracked touch-screen - I'm assuming that was what is cracked- to accept your fingertouch-inputs? Can you select items from all areas of the screen? If it was doing THAT, and it does it again NOW, I'd forget about the cracked screen , put a screen-protector on my tablet and press on ahead! Lucky dog!)
