20 Most Recent Toshiba 27A33 27" TV Questions & Answers
Main power regulator section problem. As you increase the brightness, the DC voltage from it drops. Check all the electrolytic capacitors at that section. Replace them all at one time. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window, to get gathered some pages which has the details of practical experiences to the author of that site.
Toshiba 27A33... | Answered on Mar 27, 2017
Without its original remote control, you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Toshiba 27A33... | Answered on Feb 21, 2015
assumming your remote has a keypad with a bunch of numbers 1,2,3, etc those are the channels you press the combination of the channel number you want and press enter...sscrolling up and down thru the channels is probablymore what you want, and that should be located by a set of signs wghich has horizontal or vertical arrows right nex to each other...
Toshiba 27A33... | Answered on Sep 15, 2014
Power supply regulator board fault. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Toshiba 27A33... | Answered on Jul 18, 2014
Hello
You have two options with the closed caption feature: captions or text.
A caption is a printed version of the dialogue, narration and/or sound
effects of a program. Text is information not related to the program that
appears on half of the TV screen when available.
1* Select the desired program. Closed captioned programs are
usually marked in your local TV listing as "CC."
2* Press CAP/TEXT repeatedly to select caption or text mode.
3* Press 1/2 to select the caption or text channel
4* To turn off the closed caption feature, press CAP/TEXT
repeatedly until captions or text no longer display on-screen.
Note:
A closed caption signal may not be decoded
in the following situations:
* when a video tape has been dubbed
** when the signal reception is weak
*** when the signal reception is non-standard
When you choose a closed captioned channel
and the text mode, the text screen always
appears as a black box. When there is no
signal, however, the text screen will not
display text characters. Repeatedly press
CAP/TEXT until the box disappears
If closed captioin function is intermittent, the TVs system control section has some foult with it. It will be mainly to a leaky disc ceramic capacitor in the decoder section of the internal circuit. This is not really a user servicable option. It is a skilled work. OK.
Toshiba 27A33... | Answered on Jul 06, 2011
its possibly overheating, try unplugging it for half an hour and see what happens
Toshiba 27A33... | Answered on Jan 02, 2011
Hi
U can connect the wii on ur tv . connect the component video output of ur wii to the component video input of ur tv. normally component video connections need three RCA chord for video and one two RCA chord for audio input. component video will marked as Y,Pb, Pr.
ok
Toshiba 27A33... | Answered on Dec 30, 2010
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Toshiba 27A33... | Answered on Dec 24, 2010
Hello
Picture rolling is due the fault in the vertical output section of your TV. To rectify this fault, you have to open your Tv, and locate the vertical output section inside it. It is so easy to locate as, there will be four wires going from the deflection yoke, that is the coil fitted on the neck of the picture tube, out of which, two of them will be thick, usually coloured red and blue, and the other two will be thin. Just follow the two thin wires, which will lead you to a scoket fitted on the circuit board. Upside down the circuit board, and trace the tracks of these wires, and you will reach to the vertical output section.
Normally Toshiba uses a 7 pin IC, number [TDA 8403K], in this section, the number may vary according to sets model, but the function will be the same for all. It will be screwed onto a metal hetsink. I advice you to resolder all the soldering ponts of that IC, by applying a little more solder, without making any solder bridges between the terminals. Normally this may resolve your problem, as there is a chance to get soldering loose in this section.
If this does not help, resolder the IC out, and go for a same type and number, replace it.
If you need anymore assistace feel free to contact me through Fixya. OK.
Toshiba 27A33... | Answered on Dec 20, 2010
Hello
Sorry. Your TVs front panel has no menu button to press. The only way to chane it to AV/TV, cand be done with its remote control which ahs that button to press. You just buy one new remote control, of get the present one repaired. OK.
Toshiba 27A33... | Answered on Dec 06, 2010
Thanks For using Fixya.com.
I know how hard it is to find codes for remotes and that is why I am here providing tips on tricks on how to get that code.
Click here for my tips
Be sure to read the full tip there are links to remote codes within that tip that will help you out.
Best of all be patient if your using a universal remote be sure you provide the NAME of the remote and the model number so we can get you a code sheet from the manufacture.
Please update us with the remote your using if you still are having issues, Thanks
Rulds2008/
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Toshiba 27A33... | Answered on Dec 01, 2010
hello!
about your TV,this kind of picture problem requires a technical skills to fix this error.but if you want to do it your self and have the proper tools i can teach you how to fix it.
tools needed.
soldering iron
desoldering pump
multitester
long node plier
side cutter plier
soldering lead.
Lets proceed:
The problem is on the horizontal section of the TV main board there are capacitors there that need to be replaced (be sure the TV is unplug from the outlet before proceeding) The horizontal section is the high voltage section of the TV therefore capacitors are high voltage.replace the capacitors with the same exact value.To determine the horizontal section,It's where the plyback transformer is situated. replace the capacitors near the plyback .capacitors with 10uf/250 volts and the likes.there are also small capacitors with a high voltage rating replace it.check also the Cathode Ray Tube neck there is a small board there Crt socket replace also the high voltage capacitor there.good luck please post back if you have questions thanks
Toshiba 27A33... | Answered on Nov 16, 2010
Toshiba 27A33 27" TV Logo
82 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
tv will not turn standby light
  • Televison & Video
