20 Most Recent Toshiba 36AF42 36" TV Questions & Answers
Toshiba TV model 36af42 has no picture but sound work
Engage in High-exposure Branding - Remember, a typical ad lasts about a thirty day period but an emblem item can final a number of years. How To Physical Exercise Whereas Sitting Down At Your Laptop Computer...
1/4/2017 3:49:40 AM • Toshiba 36AF42... • Answered on Jan 04, 2017
Picture goes black
GO TO MENU, THEN SETUP, SCROLL DOWN TO TIMER AND MAKE SURE IT IS ON 0 (ZERO) MIN. SOUNDS LIKE ITS PROGRAMMED TO GO SLEEPAFTER A CERTAIN TIME. THIS TV ALSO CUTS OFF AUTOMATICALLY IN 15 MIN. IF ITS TUNED TO A VACANT CHANNEL( NO PICTURE).
1/24/2016 8:09:19 PM • Toshiba 36AF42... • Answered on Jan 24, 2016
0answers
manual
Turns off and on by itself
There can be several causes for this, few of which you can do anything about. However, a few things to try.
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Good luck with your problem...I hope you can work it out.
3/31/2010 12:16:20 AM • Toshiba 36AF42... • Answered on Mar 31, 2010
My volume was going up and down by it self I had
this is a AVL problum pls. set AVLfunction is oFF than vol. is ok.
AVL [Automatic Voluem levelcantrol]
if not ok then problum is inside tv set replace adio IC suplayy ragestance . or capaceter 2200/35vdc
10/20/2009 10:35:26 AM • Toshiba 36AF42... • Answered on Oct 20, 2009
I have a 32AF43 remote has stopped working
resolder the ir sender it sound like it the solder has broken free
8/21/2009 4:28:09 AM • Toshiba 36AF42... • Answered on Aug 21, 2009
Toshiba TV Remote Control not working
REPLACE IR SENSOR INSIDE THE SET COMMON PROBLEM
5/4/2009 10:53:51 PM • Toshiba 36AF42... • Answered on May 04, 2009
3answers
Toshiba that uses CT-90040 remote
Is the cable remote a programmable universal? If so, just a matter of finding the codes to reprogram functions.
Concerning the "tuning video", are you saying that you can't get to different input sources?
3/27/2009 11:01:15 PM • Toshiba 36AF42... • Answered on Mar 27, 2009
Dead IR reciever
You don't need manuals to repair this beast.
Note all your cabling as the back plugs are many.
Remove the 8 screws in back.
Remove 4 screws using an angled phillips or angled phillips rachet that holds the left front module board in.
Carefully lift out the inter module connecting plugs. These are delicate so pry on one side with a small screwdriver then the other until it is free.
Lift out the blue LED from its holder as it is reused. Desolder the receiver. There is 5 points. Solder new part in. Reverse steps.
3/12/2009 7:27:27 PM • Toshiba 36AF42... • Answered on Mar 12, 2009
2answers
Remote optic
I HAVE NOT SOLVED THE PROBLEM YET. tHE TECH FROM YESTERDAY SAID TO REPLACE THE fios BOX. i RESPONDED BACK THAT iT WAS ALREADY REPLACED WITH THE SAME RESULTS. mY RESPONSE THIS MORNING IS DO i WANT TO PURCHASE THE PREMIUM PLAN??? I ALREADY DID AND HAVE THE RECIEPT TO PROVE IT??????? IS THIS FOR REAL. PLEASE - I JUST WANT TO GET MY REMOTE TO WORK AT ALL TIMES, NOT INTERMITTENT.
Tom Earles
609-731-1791
2/14/2009 6:11:36 PM • Toshiba 36AF42... • Answered on Feb 14, 2009
Volume on tv stopped working
HIT MENU, GO TO AUDIO (SPEAKER PIC) SCROLL DOWN TO "2ND PAGE" AND SELECT SPEAKERS ON. AND YOU MAY NEED TO ALSO SELECT SBS ON
12/27/2008 6:39:48 PM • Toshiba 36AF42... • Answered on Dec 27, 2008
Remote really?
SOUNDS LIKE U HAVE CLOSED-CAPTION TURNED ON. HIT MENU, GO TO RIGHT TO C.C.( CLOSED CAPTION) AND SELECT OFF, HIT EXIT BUTTON. GOOD LUCK
12/27/2008 6:32:07 PM • Toshiba 36AF42... • Answered on Dec 27, 2008
Help pleaseALREADY PURCHASED PREMIUM PLAN?????
The remote receiver IC costs $8 + shipping from andrewselectronics.com
Just fixed this model 2 days ago with the same symptoms.
4/13/2008 3:59:07 AM • Toshiba 36AF42... • Answered on Apr 13, 2008
TOSHIBA 36AF42
Your Fios box seems to be faulty
3/29/2008 12:46:35 PM • Toshiba 36AF42... • Answered on Mar 29, 2008
Picture tinted green
green tint & screen dark means that there is a problem in green video circuit. 1 check green video supply . 2 components in green video ckt. 3 adjustment in green video section. 4 check for signal to green video.
9/28/2007 12:33:05 AM • Toshiba 36AF42... • Answered on Sep 28, 2007
Toshiba 42RV500E sound issue
This is a known issue with this TV. The following might resolve it: Check Mute and Volume: Ensure that the TV is not muted and that the volume is set appropriately. Sometimes accidental button presses can lead to muted sound or low volume. Inspect External Speakers: If you're using external speakers, verify their connections. Loose cables or faulty speakers can cause sound issues. Test Different Inputs: Connect a non-HDMI device (such as a DVD player) to the TV. Observe if the sound distortion occurs. If it doesn't, the problem might be related to the HDMI signal from your Virgin box. HDMI Troubleshooting: If the issue persists with the DVD player over HDMI, consider the following: HDMI Cable: Check the HDMI cable for damage or loose connections. Virgin Signal: Contact Virgin to inspect the signal/lines and replace the box if necessary. Mainboard Replacement (if needed): If the sound distortion persists, it could be due to a faulty sound processor chip on the TV's mainboard. In this case, consider replacing the mainboard. TOSHIBA 42RV500E, 42RV500T, 42RV500Y, 46RV500E, 46RV500T User Guide (manualmachine.com)
4/7/2024 11:34:38 AM • Toshiba... • Answered on Apr 07, 2024
Toshiba 72HM195 has started getting red streaks
There may be loose contact or track open in main board.So try to check the main board thoroughly where you may find the loose of connection or track open.
3/25/2024 5:27:53 AM • Toshiba... • Answered on Mar 25, 2024
Toshiba 36AF42 36" TV Logo
17 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
dead ir reciever
  • Televison & Video
